02-04-2017, 04:30 PM
#41
2015 25' FB Flying Cloud
Manassas
, Virginia
Install completed today - I will post a link to the video in a week or so once I complete editing and upload it. This is one of my favorite upgrades so far. I am going to do the same thing with the bedroom TV.
02-04-2017, 06:24 PM
#42
2008 25' Classic
Full Time
Just saw a Solo 5 today at a Best Buy in Branson MO. I was able to play some demo tracks through it and it sounds pretty good with decent bass. In a small room or a trailer it appears to be the ideal solution.
Kelvin
02-05-2017, 11:31 AM
#43
2016 16' Sport
Port Angeles
We have a Solo 5 in the house. Thought we'd just grab and go when we hit the road. I'd like to have a separate power cord dedicated to the AS but figuring out which one I need is beyond my capabilities. Can anyone recommend an aftermarket power cord adapter that will work?
02-05-2017, 04:53 PM
#44
2008 25' Classic
Full Time
I don't have a Solo 5 but looking at the owners manual the power supply is a 110v cord to a brick which probably converts to DC. What are the 12v and amp ratings showing on the power supply label? The owners manual doesn't show that information.
You might be able to run the Solo 5 off a 12v source in your Airstream as long as its fused correctly. I run my Insignia 28" TV directly off my 12v receptacle on the TV wall using a cigarette plug/cable to the round power connector. Got it from Amazon.
Otherwise just bring the Solo 5 power supply with you.
Kelvin
02-21-2017, 10:41 AM
#45
2017 27' International
Graham
Originally Posted by Cispook
Would like to see some photos of your new TV install.
Taking it a day at a time ... no hurry
Same here. I figured only room for a 32 in my 27FB.
02-21-2017, 05:54 PM
#46
2008 25' Classic
Full Time
This weekend I tried out an old Bose radio I inherited from my parents. Using the 3.5mm cable from the TV I connected the TV to the radio and set the radio to about 85 for volume then used the TV remote to adjust the volume. The bass is pretty good from this device and it has a CD player. No Bluetooth but it works as a replacement for the Solo 5 for me. I may burn a CD with all or most of our music.
Kelvin
02-24-2017, 08:24 PM
#47
Manassas
, Virginia
Completed install and video has been uploaded to my YouTube Channel - what a difference in audio quality!
02-24-2017, 10:26 PM
#48
sacramento
Once again you are thinking what I am thinking
02-25-2017, 09:06 AM
#49
2008 25' Classic
Full Time
Does the Solo 5 overcome the A/C or heat pump noise adequately? Nice, clean install. Thanks for sharing.
Kelvin
02-25-2017, 09:59 AM
#50
2016 28' Flying Cloud
Brandenburg
, Kentucky
Samsung Solo Install
Installed the Samsung 40 inch 4K early last year and added the Bose Solo 5 a couple months back. The black box at the lower right of the photo is the cable box needed here at the campground I'm staying at. Makes for a messy looking install, but it just temporary. All of the TV/Solo wiring has been coiled and wire-tied behind the TV. I have about 1/2 inch clearance at upper left corned of the TV and about 2 inched between the upper cabinet flip-up door and the top of the TV. About 1/2 clearance between bottom of TV and top of Solo unit. Great sound for TV broadcast and love the Blue-tooth to play music from my iPhone. Took my old first series iPad, wiped it clean and copied a ton of music to it so I can connect via Blue-tooth to the Solo and enjoy my music.
02-27-2017, 10:07 AM
#51
Manassas
, Virginia
Kelvin
Seems like it does a good job with clarity of audio for the little bit I watched at this point. There is also a dialogue mode which I have not messed with but it supposed to help with hearing each word clearly.
02-27-2017, 09:58 PM
#52
Brandenburg
, Kentucky
The Solo certainly overcomes the A/C. Instead of having the TV speakers firing downward, the Solo shoots out towards you. Also you can adjust the Bass and the dialogue mode reduces the bass and ups the treble when activated. Having used the TV-Solo combo for the three months, I give it a 2 thumbs up.
