Old 11-27-2021, 06:46 PM   #1
2007 30' Classic S/O
2013 28' International
2006 25' International CCD
seaford , Delaware
smart tv antenna
just purchased new vizio 32in smart tv with wifi preloaded with netflix - hulu etc. what antenna should i install? thanks jack
claymanjack is offline   Reply With Quote
Old 11-27-2021, 07:16 PM   #2
2002 19' Bambi
Lafayette , California
The TV's smart features work off WiFi, not a TV antenna. If you are close to a good WiFi source, log into that with the TV. The WiFi at most RV parks is not able to provide good feed for streaming via YouTube, Hulu, etc.
Tim
Tim A. is offline   Reply With Quote
Old 11-27-2021, 07:48 PM   #3
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
I've got a similar TV in our Excella. You can use the standard rooftop antenna to get over-the-air reception. When you are able to get connected to WiFi or use a hotspot you'll be able to watch the streaming services.
Might take a little searching to figure out how to use the TV as a regular TV with the rooftop antenna but it can be done for those times you're not able to connect to WiFi.
I'm finding that more and more campgrounds have adequate WiFi for streaming. A couple have pulled their cable TV connections totally and upgraded their WiFi to allow for good streaming. It's the latest technology and campgrounds are starting to get on board.
Richard
11018
richard5933 is offline   Reply With Quote
Old 11-27-2021, 09:40 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Last year we installed a new 32" Samsung QLED Smart Television in Lucy. We have used it extensively to stream Netflix and Amazon Prime Video. This streaming has nothing to do with an antenna. On our 70 day cross country excursion this summer we did all of our streaming with our own wifi hotspot that we made with our Verizon smartphones.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
Old 11-28-2021, 09:05 AM   #5
seaford , Delaware
antenna
i do understand about streaming as i have wifi hot spot.roof antenna was what i was refering to. my bad. jack
Old 11-28-2021, 09:40 AM   #6
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
Brian
Yes; as did we! Signal strength the key, but using your cell as a "hotspot" and a decent data plan works better than relying on campgrounds, we have found.
We just did a cross country to JC Ohio, and stayed at 11 different campgrounds. Not a one had "constant", "reliable" wifi signals, and primary excuse was "campers streaming" in their rigs...(now that "was" a consistent answer!) When campers have access and many are "working" from their campers using their computers, they will use the campground wifi vs using their own data with limits...that plus streaming TV causes intermittent internet, we have found. Thats why a strong signal acquisition device seems to be a good investment...that's what we are researching now...there are a couple threads on Forum on this currently...
(I must warn you however, this seems to be like selecting a trailer hitch or a tow vehicle!)
2017 28' Twin Flying Cloud
Old 11-28-2021, 05:23 PM   #7
seaford , Delaware
hitch
Reese straight line!
Old 12-08-2021, 09:57 AM   #8
Winemaker
rgwatkin's Avatar
2022 25' Flying Cloud
Avila Beach , California
Does this Vizio work with Apply Airplay or screen mirroring?
rgwatkin is offline   Reply With Quote
Old 12-09-2021, 03:33 PM   #9
seaford , Delaware
smart tv
has air play works vg
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 11 04-03-2019 08:11 AM
Outdoor HD TV Antenna, ANTOP Flat-panel PL-402VG – 60 Miles Long Range Multi-Dir RV Antenna and installation kit alreardon Airstream Classifieds 0 09-21-2018 10:13 AM
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 08:24 AM
Rooftop Antenna Installation - Spring Mount Cellular Antenna Astw Electronics & Connectivity 4 08-04-2016 09:51 AM
Would it be smart to pour a pad? 26.982 amu Axles 17 07-19-2006 09:24 PM
