Old 05-25-2021, 04:53 PM   #1
2017 25' Flying Cloud
Cape Coral , Florida
Samsung blinking red light
Help please. 2017 FC with two Samsung Series 4 tv’s. Worked fine on trip last fall. New trip starting yesterday and they wouldn’t turn on from remote. I could get it to turn on from the button on the back but no response from remote even after new batteries. Little red light stayed lit. Tonight after setting up camp the red light flashes quickly, no response from remotes, and after hitting the button on back to manually turn on I get the “Not Available” sign on the screen and can’t turn the tv off remotely or manually. Any ideas?
Coach B is offline   Reply With Quote
Old 05-25-2021, 05:01 PM   #2
2020 23' Globetrotter
Savoy , Texas
Might be time for a new Samsung remote. Sounds similar to our Samsung. Got a new remote and it started working.
SpinWhite is offline   Reply With Quote
Old 05-25-2021, 06:02 PM   #3
DKB_SATX's Avatar
Alamo Heights , Texas
What happens to the TV if you unplug it, wait a moment or 4, plug it back in and turn it on? You SHOULD be able to control it manually with the built-in controls but it's not designed to be easy to do because everyone uses (and loses) remotes these days...
It sounds like they didn't boot up properly. All Samsung really says on the topic is that if the unplug/plug in doesn't correct it, it "may require service." Apocryphal internet comments on the topic point to HDMI issues and bad power supplies having caused this, but it sounds like the power supply is likely good since you get a screen with messages, etc. If the reboot doesn't correct it, trying unplugging the HDMI cable from the back of the TV and see if it'll behave on over-the-air content, etc.
— David
Old 05-27-2021, 01:49 PM   #4
This unit has two tv’s, they both act the same. No response to either of the remotes. The blue ray will play on the front tv but I can’t get past the intro where you have to click play. Blue ray remote doesn’t work on the blue ray or control the on/off on the tv. Don’t get any signal from tv antenna.
Old 05-27-2021, 03:04 PM   #5
DKB_SATX's Avatar
It's potentially interesting that the blu-ray remote doesn't work on the blu-ray player or the TV. If it were just the TV near the blu-ray and the blu-ray having this problem, I'd look for a source of bright IR light in that area, but I'm guessing the bedroom TV isn't in line-of-sight to the other 2 gadgets. I can't imagine what's affecting BOTH the TV remote and the blu-ray remote unless it's just enough infrared noise to block the signal.
— David
Old 05-28-2021, 06:05 AM   #6
Thank you, David. When I do get this resolved I will post again.
Old 06-10-2021, 11:41 AM   #7
Found a solution
Ended up purchasing two new televisions and a blu-ray player. Hooked them up and all is fine. Must have been some unknown “shock” that took out the original TVs and player.
Replaced 28” Samsung with 32” Samsung wbrown Audio, Video & TV 33 01-20-2019 09:20 AM
Samsung Note 4 to Samsung TV Drcrow Our Community 0 07-07-2016 09:32 PM
Connecting Samsung phone to Samsung TV Drcrow Audio, Video & TV 1 06-15-2016 08:29 AM
Systems Monitor - blinking red light? time2play 2009-2015 Flying Cloud 0 05-18-2013 07:19 PM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
