Old 10-05-2023, 08:37 AM   #1
2023 25' International
2018 Interstate Lounge Ext
College Station , Texas
Red light on top of the antenna
WhatClick image for larger version
ID:	437515 is this red light on top of the trailer for? 2023 International 25FB
1st time RV is offline   Reply With Quote
Old 10-05-2023, 08:43 AM   #2
2023 28' International
Mercer County , New Jersey
It means that it's powered on. If you turn off the antenna using the switch next to the TV, it'll go off.
One note - the antenna is also used by the radio so it needs to be on if you want to use the radio.
jeffb831 is offline   Reply With Quote
Old 10-05-2023, 07:06 PM   #3
2023 30' Globetrotter
Arizona City , Arizona
On our 23 Globetrotter 30RBT, the light on the antenna is on even if the antenna booster is off. We can see it through the skylight.
We are currently at a park hooked up to cable in Raton NM where there is no over the air channels, we have the TV on and the cable is working so I know the booster is off, and I can see the red light from from the lounge.
And yes, with the booster off, the radio does not get any antenna signal.
Not sure where that red light is powered from.
gypsycoder is offline   Reply With Quote
Red numbers on top captlou Airstream Motorhome Forums 3 11-28-2016 05:05 PM
Best route from Red Top Mountain to Memphis Airstruck On The Road... 1 07-08-2015 07:12 AM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
Optima AGM Red Top start Battery Install John H. Classic Motorhomes 8 03-19-2011 09:17 PM
Top 20 Contributors, Top 10 Forums/Threads & New Stats Info.... Andy R Our Community 7 04-01-2008 09:19 PM
