10-03-2022, 11:21 AM
2017 27' Flying Cloud
Chillicothe
, Ohio
Radio Powers on Randomly
2017 FC and twice in the past week my radio has powered on randomly. No pattern or event repeated. It’s hooked up at home on 30a.
Anyone encountered this? Time to update the radio system?
10-03-2022, 09:25 PM
Chillicothe
, Ohio
No one?
10-03-2022, 10:53 PM
Boise
, ID
I really haven’t used mine. I’ve noticed it on a couple times. No volume though. It’s a tough call with a 13 year old on board. He may have turned it on.
10-04-2022, 05:36 AM
1994 25' Excella
Waukesha
, Wisconsin
Does the radio have an optional remote control?
I've had situations where devices with remote control functions have been turned on by other nearby radio transmissions or other remotes being used nearby.
Richard
11018
10-04-2022, 06:37 AM
Chillicothe
, Ohio
I don’t think there is a remote. I did do a hard reset. If it happens again I’ll remove the faceplate for the time being.
All the online research indicates the radio is failing if the reset doesn’t work.
10-04-2022, 10:57 AM
2018 16' Sport
Milwaukie
, Oregon
On my 2018 the radio turns itself on every time the shore power is turned on, or there is an interruption in power.
I now take the face plate off unless using the radio.
10-04-2022, 12:27 PM
2012 23' FB International
Woodstock
, Ontario
I would be taking a second look at this. I had a bad battery getting drained several homes before I discovered that the radio ( inside a covered overhead) powers up each time 12V power is restored.
Charged the battery at home and dead again the next day
10-04-2022, 01:48 PM
2019 23' Flying Cloud
2022 27' Flying Cloud
ALLEN
, TX
In my 2022, every time I turn on 12v (take it out of storage mode), the radio power turns on. There is a cover on it, so it's easy not to notice. I just put it on my checklist for things to check...
Scotty
10-04-2022, 02:09 PM
Chillicothe
, Ohio
Seems power surges are a common factor. I’ll start removing the face plate. Put a newer system on the update list.
10-04-2022, 04:32 PM
Boston
, Ma
The head piece airstream and most others use are Car stereo’s. While many OEM radio’s will return to “last mode” when powered (turning car on) aftermarket like Sony are usually programmed to turn on. That being said if there’s the slightest drop of shore power, (which happens, sometimes w see all our home lights just dim and barely notice) that shift from shore power to battery back to shore power could very well be culprit ie: you could be chasing a power grid issue wouldn’t dig to deep if pulling faceplate off works
2005 25’ Safari Special Edition (International Package)
Sendel 16’s, Michelin Cross Climate, Shell on interior update (floor frame solid) Ampere Time lith batts, Victron Controls, Champion Dual Fuel 3400
WD Eaz-Lift 2 -1200lb bars 2-anti sway brakes
10-08-2022, 02:06 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
My radio is designed to power on anytime the trailer's DC is on. They were designed this way to keep their memory powered up.
guskmg
12-05-2022, 06:20 PM
Winemaker
2022 25' Flying Cloud
Avila Beach
The only other thing that I can think of is, is perhaps when the unit is off, it is really in a standby mode (with power to the chasis) and it temporarily loses with power or ground and then reinitiates startup? In both AS I have owned I installed a separate power switch to prevent startup every time the master switch is turned. Both Sony and JBL have this problem.
12-05-2022, 06:31 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Same-O...plus it's a constant draw.👍
“Listen, or your tongue will make you deaf” Native American proverb.
12-05-2022, 07:46 PM
2008 22' Sport
Spicewood (W of Austin)
Our 22’ Sport has a Sony AM/FM/CD player that will drain the battery if left intact… because is constantlyi in “standby”mode…. no way to turn truly turn it off…except to open it’s front-face. (Being an automotive radio it ha a face-plate designed for removal to discourage theft. Removing…or partially removing/opening the face-plate prevents it from drawing any power. I keep telling myself that some day I will open the cabinetry and install a power/supply switch …but so far…we simply open the faceplate)
