Playing CD in models with BluRay
I have noticed since Airstream has begun installing Blu Ray players in new units, there is no easy way to play a CD. Since I have been asked by nearly every customer how to do this when I perform a walk-through, I thought it would be good to share the procedure somewhere that could be referenced if, for example, I get run down by a bus one day.
The procedure is as follows:
1-- Connect trailer to 120v power source.
2--Turn on Blu Ray player, television, and radio.
3--Open the menu on the television, and choose "HDMI 1" for source.
4--Open the menu on the radio, and select "AV1" or "Input 1".
5--Insert CD in Blu Ray player, and select "play".
6--Adjust volume by using the volume buttons on the radio, and change or select tracks by using the remote for the Blu Ray player.
The 120v needs to remain connected for the Blu Ray player and television to continue operating, and sending the audio signals to the radio.
