Old 09-22-2021, 06:55 AM   #1
Pbfec
2019 25' Flying Cloud
jupiter , Florida
No power to tv, blue ray, dinette receptacles, bedroom tv
2019 AS Flying Vloud 25 RB Twin. Sudden loss of power to the tv,blue ray player, bedroom tv and receptacles. No breakers tripped, reset all breakers and still no power. I am Connected to 50 amp power at campground. If I hit the inverter switch I get power to all connected to inverter outlets. Wonder if a breaker has gone bad? Need any help! Thank you in advance.
pbfec1 is offline   Reply With Quote
Old 09-22-2021, 07:36 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Battery use store switch? Set to store?
Old 09-22-2021, 09:16 AM   #3
DKB_SATX's Avatar
Alamo Heights , Texas
It seems that the problem is the INPUT power to your inverter. The outlets you describe are the inverter-backed ones, right? So, when on shore power you have power to the outlet in the galley, and the bedroom one that's not right by the TV even with the inverter off? I'm guessing it's either the input line for your inverter pass-through (disconnected, breaker or fuse blown, etc) or the pass-through function itself has failed.
— David
Old 09-27-2021, 09:09 AM   #4
Pbfec
jupiter , Florida
Thanks for the information. We have located the issue in that the plug from the inverter was not seated in the outlet. Would have been a bit easier if Airstream had told me the correct location of the inverter and how to access.
Glad it was so simple a fix.
2016 International Series 23D — HDMI Cable and Blu Ray/Blue Tooth Clarion Radio PaulKatie General Repair Forum 3 08-08-2020 07:46 PM
Blue ray player no wifi, too bad Plasma800 Audio, Video & TV 15 10-11-2016 09:20 PM
no power to 110 receptacles hahnstead General Repair Forum 16 03-16-2016 10:06 AM
Blue Ray sound through Kenwood mmmmm Sprinter and B-van Forum 6 05-28-2015 07:10 PM
Run power off two 20amp receptacles? KYAirstream Electrical - Systems, Generators, Batteries & Solar 10 10-29-2012 10:19 PM
