Fixed!
I reached out to the factory and received all the schematics within an hour of requesting them. Very happy with how fast they responded.
I then checked the diagram, verified that yes, there should be a control wire connected. After much struggling to get a splice connected to the too short wire I tried it. Nothing. Fussed some more and discovered that someone had peeled back the factory setting sticker and saw the selector switch was on remote vs signal. I moved it to signal, after a moment the power light turned green and it started functioning. Guessing that a tech previously tried changing that without knowing it wasn’t fully wired.
Thank you again for your help in getting it figured out and repaired!
Jason
Jason & Veronica J.
S.E. Michigan
2022 Caravel 22FB
Former caretakers of 1955 Commodore Vanderbilt 30'
