Old 03-24-2023, 10:06 AM   #1
2022 22' Caravel
Fuquay Varina , North Carolina
no cable TV
We have a 2022 22FB Airstream Caravel, with a problem with accessing cable TV. No cable reception after trying at many different campgrounds. Any thoughts on what might be wrong? Do I need some type of box, in addition to the coax from the campground to my trailer input? thanks!
gratefulsinr is offline   Reply With Quote
Old 03-24-2023, 10:16 AM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Check your manuals for operation ...
TV Wall Plate Power Supply
The wall plate/power supply provides 12 VDC to the antenna as well as antenna signals to two TV sets. Cable input from the outdoor receptacle connects to the wall plate and may be switched so either antenna or cable/satellite signals may be watched.
Operation
To receive cable signals from the outdoor receptacle: Press switch to OFF position. The light on the wall plate will go (OFF) showing that power is no longer connected to the antenna and that both TV sets are receiving signals from the outdoor receptacle.
To receive signals from antenna: Press switch to ON position. The light on the wall plate will come (ON) showing that power is connected to the antenna and both TV sets are receiving signals from the antenna.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 03-24-2023, 03:14 PM   #3
1988 32' Excella
Robbinsville , New Jersey
First, as SeeMore said antenna booster most be off to receive cable in trailer.
Second, in many campgrounds you need a cable box to get any channels. Ask the host or another camper if it is needed. Note most people don't bother with a cable box for 1 or 2 nights so sometimes the host may not mention them and sometimes they run short of cable boxes so don't mention them unless they are asked.
Old 03-24-2023, 09:07 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Some trailers have two external coax connectors, one for cable and one for satellite. If you have the amplifier off and are on the right cable, try the other one. Reversed connections have been reported.
Al
Old 03-25-2023, 05:12 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Cable
It has been my experience that providing good quality cable is not a probity for many campgrounds.
Crushed my trailer cable with my ProPride hitch. How do you lay your cable? jondrew55 Towing, Tow Vehicles & Hitches 22 07-25-2022 05:51 PM
Strange issue with TV cable connection when on campground cable kittmaster Audio, Video & TV 10 09-08-2021 06:16 AM
Cut-Off Switch for House Battery: Install on the Negative Cable or Positive Cable? Searching Batteries, Univolts, Converters & Inverters 27 04-18-2020 06:08 PM
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
accelerator cable islandvu3@cox.net Airstream Motorhome Forums 1 05-26-2002 11:02 PM
