Old 06-17-2024, 01:30 PM   #1
2020 27' International
St Augustine , Florida
JL MM50 failed
The screen has failed on the JL MM50 radio.
What other make/models have people replaced the radio with?
Prefer to just use same size hole but can make larger if I have to.
The Boot is offline   Reply With Quote
Old 06-22-2024, 05:05 PM   #2
This is the radio screen, fixable or kaput?
Old 06-22-2024, 05:42 PM   #3
DKB_SATX's Avatar
Alamo Heights , Texas
The stereo continues to function, but the screen is messed up? (...and so far not too messed up to see what it's displaying...)
If so, I think that gives you plenty of time to select a replacement.
It looks like a problem with the LCD itself. That radio is a weird form factor, I'm not sure why they went with it... maybe for the large display?
ó David
Zero Gravitas ó 2017 Flying Cloud 26U | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire. ó Sir Winston Churchill
Old 06-22-2024, 05:57 PM   #4
it still works, and I will keep using it till it dies but I do not understand why Airstream would not put in a single din/ double din radio and make it easy to replace the head unit .
Now I have to find a radio and cut the hole bigger.
Old 06-23-2024, 06:57 AM   #5
InvertdEagle's Avatar
2023 33' Classic
Manassas , Virginia
The radio is a marine radio that Airstream uses. Itís nice because itís hardened and somewhat weatherproof. The screen itself might be replaceable through JL Audio directly. The screen usually just plugs in much like a cell phone screen. The hard part of such a repair is separating the screen from the chassis - they usually Ďsnap iní and arenít really designed to be removed. Or, if you feel like dropping the $$ you can replace it with a brand new one of the same type (no hole cutting, etc.) for around $450.
InvertdEagle is offline   Reply With Quote
Old 06-23-2024, 11:34 AM   #6
Yep looked at those options but looks like only the mm50 fits that hole, all others have to be enlarged.
Would have made more sense to have put in a standard din radio size. Really do not need weather proofing on an inside radio
JL MM50 Problems rgwatkin Audio, Video & TV 1 03-15-2022 06:02 PM
JL MM50 no remote? The Boot Audio, Video & TV 13 03-15-2022 12:28 AM
Bluetooth speaker and JL MM50 FCMike Audio, Video & TV 1 02-06-2022 01:44 PM
Smart tv bluethoothing to JL MM50 bparrish Audio, Video & TV 0 03-22-2021 12:19 PM
Sony DVD and JBL MM50 - Factory Items Gtx Eng 2016 - Current Flying Cloud 23 01-18-2021 01:42 PM
