06-15-2007, 02:41 PM
1971 27' Overlander
Central
It Won't Stay Up
I have an original antenna on a 71 Overlander. When you crank on it the leading edge raises about 8 inches but then it suddenly drops back about 5 inches. Crank on it again and it does the same thing.
Any ideas as to what's causing my problem.... Thanks.
06-15-2007, 02:45 PM
1960 22' Safari
in the wilderness
, The great Mojave Desert
What a thread title!
So many many jokes I can't make on a family forum.
Don't worry someone who is not a wise acre like me will give you a usefull answer.
WBCCI 3344 FCU
AIR# 13896
CA 4
06-15-2007, 02:53 PM
2002 25' Safari
Dewey
Yes, the title of the thread is an eye catcher!
The antenna crank is attached to a worm screw which inturn drives a gear that raises the antenna. I suspect that the gear is stripped at the location where it fails. You might want to invest in a new bat wing antenna rather then look for parts for the one you have. At least it doesn't leak!
Richard
06-15-2007, 03:18 PM
Central
, Mississippi
If the design is the same at the newer "Monument to the flying Nun" types, it's an easy and common fix. Almost any RV dealer will have the two plastic parts.
06-15-2007, 04:25 PM
Silver Mist
Riverhead
, New York
You need to put a little blue pill in the gears
06-15-2007, 09:10 PM
1971 27' Overlander
Central
Ran out to the c/ground tonight to finish painting the emblems. Quick look at the antenna setup - how do you get to the gears? Do I have to remove it or can I get to them from the inside.
06-15-2007, 11:41 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We all have that problem once in a while.
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
06-16-2007, 08:15 AM
1977 31' Sovereign
1989 34' Excella
Johnsburg
Unfortunately, you can not get at the gears from the inside. You have to take the antenna off the roof and dismantle it. When it happened to mine, I went to a batwing. The amplified version has the amplifier in the head and it therefore much better than the old Clothes hanger type that has the amplifer in the wall of the trailer.
06-16-2007, 08:54 AM
1975 31' Sovereign
Searcy
, Arkansas
I tried it!!!
Now my antenna is up so high the BBC is coming in like it is right next door!
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
07-01-2007, 08:43 PM
1978 28' Argosy 28
sarasota
the old " clothes hanger type " works very well, clean the elements with a brillo pad, eleminate the 300 ohm twin lead, replacing it with RG 6 or better coax and you can forget about needing the amplifier for most reception area's
07-01-2007, 08:47 PM
1978 31' Excella 500
Venice
If you change to a new style antenna, remember that the old one is "trade goods."
07-02-2007, 04:37 AM
1971 27' Overlander
Central
Haven't tackled the job yet. I did inspect it and all the fasteners are rusted so I got all new brass screws - stainless wing nuts, etc.. It has coax patched to ribbon cable above the roof and ribbon cable inside. There's no way to replace with all coax - the ribbon runs out of a cabinet - behind the wall then up to the antenna by the vista view.
I think it just needs some tlc and the new gear set (which I have now - thank you all) - but we will see.
07-02-2007, 04:49 AM
1984 29' Sovereign
Savannah
Cute...
AFTER THIS..I nearly broke the handle..it wouldn't come down~!!
THANKS FOR THE SMILE...
WBCCI 5292 AIR 807
NEU #64
New England Unit
02-21-2008, 04:30 PM
1971 27' Overlander
Central
Just an update here. I didn't get around to removing and rebuilding the original Braund Skyliner antenna last year. But, it worked out OK. This week we found an original Braund Super Skyliner - the seller said it was new. It came today in the original box. It still has all the parts in the packing bag including a spare gear set, the wall amplifier box and a new aluminum roof support for it to rest on. Sometimes you just get lucky....
02-21-2008, 04:41 PM
Always Airstreaming!
2005 22' Safari
1960 24' Tradewind
Anytown
, Connecticut
I just checked our worm gear and it seems ok! There is a bit of a kink, is that OK?
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
1964 17' Bambi II
Schererville
, Indiana
My Braund Skyliner reception wasn't too great until my brother, who does dish installations, put new ends on the cable. Viola! It gets great reception now, even way out in the country! I put new gears in the one on my former trailer & it wasn't that big of a deal to do. The roll pin that was in there was the tuffest part for me to remove. Have fun up there!
Becky
1964 Bambi II
1988 Avion 32S
02-21-2008, 04:42 PM
1964 17' Bambi II
Schererville
, Indiana
That's really gross!
Becky
1964 Bambi II
1988 Avion 32S
02-21-2008, 04:48 PM
West of Fort Worth
Actually pretty funny.
02-21-2008, 04:50 PM
1971 27' Overlander
Central
Must be a guy thing.
