Old 04-14-2020, 02:30 PM   #1
2019 33' Classic
Maplewood , Ohio
Installing Disney+ to Projector TV on '19 33' Classic
Has anyone been successful in installing Disney+ on the LG projector TV in a 2019 Classic 33? We're having trouble and would appreciate some assistance on how to set this up.
Thanks in advance
jkingseed is offline   Reply With Quote
Old 04-14-2020, 04:30 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Can you plug an HDMI cable into the projector? We do a AV connector to our phone and stream from our phone. Works with Netflix too.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 04-14-2020, 05:02 PM   #3
2019 33' Classic
Maplewood , Ohio
BSWY,
I looked on the sides/front of the projector earlier today and didn't see anything. I'll look again. Projector is mounted close to the wall, so not sure if there is a connector on the back that is easily accessible. Will look into this further, as well. Thanks for the reply. Does the 30' Classic have a projector as well? Will send more info when I take a further look.
Old 04-14-2020, 08:58 PM   #4
2018 30' Classic
30 has a standard LCD Tv. Do you have a Blu-ray player? You may be able to grab that HDMI cable?
If yes, you can also buy an HDMI switch that allows you to switch HDMI ports with one cable. I have it in mine to swap between PS4 and the AV cable.
BigSxyWhtGuy
Old 04-15-2020, 04:41 AM   #5
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
Thanks in advance
Sorry I don't know specifically, but there is a couple of ways.
As said before
Use your notebook to stream the movie - HDMI cable direct to the projector ----but you would need sound.
Use your notebook to stream the movie - HDMI cable to the DVD player INPUT?
Use your notebook to stream the movie - HDMI cable to the BOSE soundbar?
Use your CHROMECAST / APPLE TV / ROKU / PLAYSTATION to stream the movie - HDMI cable to the same as above.
Tow Vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L - 2012 Mercedes Benz GL350d - [not set up yet, should i?]
Ultraclassic is offline   Reply With Quote
Old 04-15-2020, 04:43 AM   #6
2000 30' Excella
GTA , Ontario
As said before
I also remember a post about someone changing the couch to chairs? and the entertainment center hook ups was UNDER the couch?
Old 04-15-2020, 01:59 PM   #7
JDG
Riveted
JDG's Avatar
2018 33' Classic
Charleston , West Virginia
Does your projector look like this? If so you should have the ports on the side. I believe mine are on the side facing the front of the Airstream.
JDG is online now   Reply With Quote
Old 04-15-2020, 02:52 PM   #8
2020 Classic 33
Box Elder , South Dakota
Pretty easy to do. Buy a ROKU connection, like the Roku Streaming Stick+. I plugged the Roku stick in the HDMI port on the auxiliary panel next to the radio and the Roku USB plug into one of the USB ports on the same panel. Then you can use the Roku device to get to the Disney+ app.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 04-15-2020, 03:29 PM   #9
2019 33' Classic
Maplewood , Ohio
All. Thanks for all the direction. I was able to get it to work today. Tore the whole electrical system apart, more so, so that I kew what wire/USB/HDMI was going to what. Projector, radio receiver (or whatever it was), splitter, DVD, outlets, and wires that ran down/behind the wall. I now have a diagram to reference in the future rather than tear everything apart. There's a lot of components and wiring in a small space. I was successful in being able to connect to the "auxiliary" HDMI port at the "auxiliary" connection ports above the projector and below the DVD player. For now I have to sit the computer in the side cabinet and run the HDMI cable from the computer to the aux. HDMI port.
JDG - we have an LG HF80JA in our unit. No connections the side. All were in back. 2 usb, 2 HDMI, 1 cable, 1 audio and 1 power are used. I believe there were a few other avaliable connections, but not used so I didn't pay a whole lot of attention to them
ghaynes755 - I'm curious if the ROKU will allow me to get Disney+ directly in the trailer without the use of the computer. That would be the ultimate goal. Electronics is not my specialty by a long shot, so I'm limping thru this. I'll look into the ROKU.
Thanks again
Old 04-16-2020, 09:11 AM   #10
2020 Classic 33
jking, no need for a computer with the Roku. No need to open up the panel to the rat's nest of wires. I did the same thing and then bought the Roku. I've got the stick on the projector panel and another one, non stick model, in the bedroom. They work great.
Besides something like Disney I get all of my news channels, sports, movies over Roku.
Gary
NVPN
Old 04-17-2020, 03:49 PM   #11
2000 30' Excella
GTA , Ontario
It is a Streaming device so it can replace your PC, but will need Wi-Fi. Your notebook can do Wifi, play DVDs, and play downloaded movies on it's hard drive when out of internet range....so have both
Classic 33 Projector TV smmckean 2016 - Current Classic (all lengths) 110 07-03-2020 07:59 AM
Installing a 2nd fridge in 22' Sport (or installing larger fridge altogether)? skicrazy801 2005 and newer - Bambi all models 12 09-22-2019 01:43 PM
33 Classic Projector Bug davcarv 2016 - Current Classic (all lengths) 3 08-29-2018 07:38 PM
Disney, (Ft. Wilderness) in the Fall Pick On The Road... 14 11-22-2009 10:14 PM
Disney-MGM Studios dmac Our Community 12 12-30-2005 04:38 AM
