Old 09-19-2020, 07:48 PM   #1
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
Inside SAT connector location
Hi,
I have a 2020 28 RBT Flying Cloud and am trying to locate the interior connector for SAT. The manual states:
Your unit is pre-wired for a portable satellite antenna� The exterior inlet is located on the side or rear panel of the trailer and is labeled for your convenience� The interior pre-wire, consisting of a 2-pin power/ground connector and a coax cable pigtail, is located in the front roof locker under the Blu-Ray player�
I looked in the cabinet and saw no such connector. Would the pigtail be actually behind the wood panels that must be removed? Does anyone have this same trailer or experience with this?
Thanks in advance for the help.
KK4YZ is offline   Reply With Quote
Old 09-19-2020, 07:54 PM   #2
2018 25' International
Slidell , Louisiana
Yes the wires are under the blue ray particle board melamine mount. There are two screws on the exposed side covered by plastic plugs. Remove them and the whole thing comes loose. You can also dislodge the velcro holding the blue ray player in, pull it out and fish the wires out but removing the whole rack is easier.
Brian
BayouBiker is online now   Reply With Quote
Old 09-20-2020, 05:30 AM   #3
KK4YZ's Avatar
Hiawassee , Georgia
Thank you, sir. I just wanted to confirm before I take it all apart. Probably need to do so anyway because Im not thrilled with the way the AV equip is set up.
Have a good day.
Old 09-20-2020, 12:05 PM   #4
pbarstow's Avatar
2016 26' Flying Cloud
1988 32' Excella
anchorage , Alaska
Why, oh why does Airstream continue to hide the satellite cable connection??? Were on our third AS, a 2020 fb GT, and once again I had to take apart the whole setup to get at the sat cable hidden inside the wall. They bring all of the other cables through to connect the radio and dvd...they should include the sat cable!
Ok, Im done with my rant.
pbarstow is offline   Reply With Quote
Old 09-20-2020, 04:08 PM   #5
KK4YZ's Avatar
Hiawassee , Georgia
Yeah, I know. I should get in there anyway to see how things are connected. Ive not been able to get the audio from the blu ray player to play through the sound system. Im gonna make that happen if I need to replace the audio system.
Sat Antenna Location gdead Sprinter and B-van Forum 23 08-02-2013 08:26 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
Mounting Sat Receiver. Location? TexZen Computers, Internet & Satellite 4 03-02-2008 03:00 PM
Sat. Receiver & DVD Player Location KANEHILL Audio, Video & TV 4 12-13-2007 02:38 PM
