Old 10-08-2020, 07:40 PM   #1
Spartanguy's Avatar
2021 19' Bambi
San Francisco , California
Help needed, bedroom TV dead
My bedroom TV (Samsung 22 inch UN22F5000AF) on my FC died. Airstream has gone to LG and I think I know why now, I’m not seeing a 22 inch Samsung being produced anymore. If it’s larger the TV will be in the way of the thermostat.
Does anyone know what the model of the LG TV is on the 2020 Flying Cloud?
Is having an LG in the back and a Samsung in the front going to cause me problems since the back TV acts as a slave to the front when on?
Does anyone know where I could get a UN22F5000AF? Only one on eBay and parts only, screen also out.
Not sure what to do here...
Spartanguy is offline   Reply With Quote
Old 10-08-2020, 09:39 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Back in 2013 when the model inventory was high the 22" sold in the mid $100s. Here is a link to a seller with one still in stock:
https://www.willoughbys.com/Samsung_...el_238847.html
It might be worth installing a true 12 volt, moisture and vibration ruggedized TV depending on how you use your unit. This 28" diagonal is a mere 2 inches wider with a substantially larger image:
https://www.amazon.com/dp/B07C1D8FKJ
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 10-08-2020, 09:50 PM   #3
Spartanguy's Avatar
2021 19' Bambi
Oh thanks! Yeah that back TV gets a lot of wear with me moving it constantly in and out of locking position. Still don’t know how going non Samsung would work out though...
Old 10-08-2020, 10:04 PM   #4
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
I have the aforementioned Samsung model. One died a few years back and it's replacement is still going strong. I removed the converter block and wired power directly into the 12 volt which allows use without the need for 110-120 utility power - great for checking weather/news at a rest stop grabbing lunch on the road.
As regards two different manufacturer's TVs, I don't know how you are wired for signal in your trailer, but mine allows all over-the-air channels from the antenna to be available to both TVs so different shows can be seen simultaneously. If you use a satellite/cable converter box, then only the selected channel is seen on both TVs.
Sir Tristan
Old 10-09-2020, 05:45 AM   #5
2023 27' Flying Cloud
Wapakoneta , Ohio
This is a great 22" TV that has lots of inputs: https://www.bestbuy.com/site/insigni...?skuId=6260936
To be honest a TV is a TV - nothing special about mixing and matching brands. This TV has the same universal holes necessary to screw it onto the wall mount.
jagpanzer is offline   Reply With Quote
Old 10-09-2020, 06:56 AM   #6
Spartanguy's Avatar
2021 19' Bambi
Much appreciated. The mounting holes was a concern too.
Old 10-09-2020, 09:15 AM   #7
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
TVs these days have standardized VESA mounting holes. I’m not sure how far back that goes. A new mount isn't very expensive if you have to replace it.
daleyocum is offline   Reply With Quote
Old 10-09-2020, 10:41 AM   #8
1988 32' Excella
Robbinsville , New Jersey
From my experience most of the time you are better off with different brands of TVs in tight areas. Gets rid of the problem of controlling the wrong TV with the remote.
Old 10-09-2020, 10:58 AM   #9
The Colonel's Avatar
2017 25' Flying Cloud
Florence , Alabama
I put a 28’ Smart TCL in my bedroom, it doesn’t interfere with thermostat
I did add a small wood block the allow the fit. Works great for me
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 10-09-2020, 01:57 PM   #10
Spartanguy's Avatar
2021 19' Bambi
I bought this TV today, thanks for the recommendation!
Old 10-12-2020, 09:37 PM   #11
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Video Electronics Standards Association (VESA)
Originally Posted by daleyocum View Post
tvs these days have standardized vesa mounting holes. I’m not sure how far back that goes.
1997
Sir Tristan
<2mo Old - Dead Batteries Dead Electricals GT2018WA Electrical - Systems, Generators, Batteries & Solar 9 05-29-2018 01:48 PM
house battery seem dead/ shore power dead joe rv guy Sprinter and B-van Forum 29 12-26-2016 12:36 PM
07' 25ft FB Safari Bedroom 110 Outlets dead mgm Electrical - Systems, Generators, Batteries & Solar 8 04-07-2016 11:10 PM
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
