Old 07-19-2023, 11:56 AM   #1
Va Old Salt's Avatar
2025 33' Classic
Virginia Beach , Virginia
HDMI Port in New Globetrotter
We have a 2023 GT 30’ which comes with an HDMI port instead of a DVD. I have been unable to get an Apple TV to work through the port. If I hook it up directly to the individual TVs, it works fine. I have turned off and even disconnected the over-the-air antenna booster. Cycling through the various inputs on the TVs has no affect. Am I missing something? TIA
Va Old Salt is offline   Reply With Quote
Old 07-24-2023, 05:15 AM   #2
AppFan's Avatar
2023 27' Globetrotter
Charlotte , North Carolina
It should "just work". We use a Roku stick with no issues. Of course check the basics... Apple TV plugged in? Correcting input selected on the TVs?
Any chance something came loose behind the HDMI panel? You may have to take a peek behind it.
AppFan is offline   Reply With Quote
Old 08-06-2023, 03:40 PM   #3
2023 25' International
2021 22' Caravel
Horse Shoe , North Carolina
Same issue but different
I’ve got a 2023 International .. when i connect the Apple TV to the HDMI input above the table .. I can watch it on the TV in the bedroom but not the other TV in above the couch (the “main” TV) I tried all the inputs available on the TV and still nothing. However if I connect the Apple TV directly to the “main” TV it works fine.
Any insight would be much appreciated
trichef1 is offline   Reply With Quote
Old 08-06-2023, 06:04 PM   #4
2024 30' Globetrotter
Houston , Texas
Following
FredWilma is offline   Reply With Quote
Old 08-06-2023, 09:05 PM   #5
2023 25' Flying Cloud
Franklin , Tennessee
AppleTV works intermittently on my 2023 FC to both TVs. Must be a bad cable or loose connection. It’s on the punch list for JC this fall.
2023 25RB Twin Flying Cloud
2024 GMC Sierra 1500 Denali w/ 3.0L diesel
BRN# 3612
TNOutback is offline   Reply With Quote
Old 08-07-2023, 11:56 AM   #6
TrvlTin
2023 30' Globetrotter
Boulder , Colorado
Didn’t we all go down this rabbit hole on earlier post??
https://www.airforums.com/forums/sho...d.php?t=245331
TrvlngTinTin is offline   Reply With Quote
Old 08-07-2023, 11:58 AM   #7
TrvlTin
Boulder , Colorado
Yes exactly! For me. It was the pass-through on the wall plate under the stereo..
Old 08-07-2023, 12:06 PM   #8
TrvlTin
Boulder , Colorado
Old salt,
Let’s try again..
Did you try to replace this??
Or test it?
Again to test you need to remove 4 screws. Can do in under a minute.
[ATTACH]435155[Click image for larger version
Old 08-07-2023, 12:12 PM   #9
TrvlTin
Boulder , Colorado
With one of these[ATTACH]435157Click image for larger version
HDMI Switcher with 3 inputs ghaynes755 Audio, Video & TV 1 04-29-2014 08:42 PM
any residents of Sequim ,Port Townsend or Port Angeles kingfisher24 On The Road... 6 10-15-2013 08:57 AM
Adding HDMI to Bedroom emdubyadee Audio, Video & TV 21 03-31-2013 10:25 PM
HDMI Splitter Cable GerryH Audio, Video & TV 1 12-14-2011 11:26 AM
HDMI cable for 20' Flying Cloud mistermcfrug Audio, Video & TV 18 02-09-2010 02:22 PM
