Old 10-23-2018, 07:26 AM   #21
LuLuAdrift's Avatar
2016 22' Sport
Leesburg , Florida
Originally Posted by whbrown View Post
Went through all the options on the JVC including AUX, nothing there. I would suspect on the Sport model, they choose a very basic radio. I'm surprised it does have FM. I'm really disappointed with AS on this. I've looked on the back of the TV and it does have a HDMI cable on it that goes into the wall to somewhere. I'll pull the radio out and see if anything is going into the inputs. The AS manual gives not clue on what is going on.
Same here. 22 Sport 2016 and only tuner or aux front plug. DVD does play through the radio speakers but not TV.
LuLuAdrift is offline   Reply With Quote
Old 10-24-2018, 07:11 AM   #22
kpm
2018 25' International
Mound , Minnesota
Airstream seems to buy the least expensive components that will fit in the space. Our complaint is the the model of our Samsung TV. The tv has no broadcast guide for antenna reception. We often like to check weather in a new location and we're reduced to blindly scanning all channels. I checked one time, and it would have cost $10 more for a slightly better smart tv that supports a guide, as well as Internet streaming.
In your case though, I would call Airstream customer support before replacing my unit. I've found them to be helpful and thorough.
kpm is offline   Reply With Quote
Old 10-24-2018, 09:29 AM   #23
2018 22' Sport
Fort Myers , Florida
You are missing a part. Same thing happened to us. In the box the JVC radio sits on - unscrew it, are a lot of wires. You need to buy an adapter to plug in the HDMI cable that comes from the TV on one side, and the yellow, white a red adapters to the other. When you play a DVD the sound will come out of the speakers. for just the TV channels, i cannot get the sound to play thru.
I got my converter on amazon - "HDMI to composite AV converter". When I finally got someone at the factory to reply, this is what they said should be there, and when installed it worked.
The CD player is behind the face of the JVC. just open it will the little button.
Lilyfielding is offline   Reply With Quote
Old 10-25-2018, 06:23 AM   #24
2018 22' Sport
Ludlow Falls , Ohio
Thank you Lilyfielding, can you now get the TV to play through the house speakers when just watching air channels? If so, I'm going to give that a try.
whbrown is offline   Reply With Quote
Time for a Life Change mpsgolf On The Road... 2 08-18-2016 02:44 PM
Electric Grills, do they not get hot enough, are they a waste of time? adiben On The Road... 17 06-01-2015 10:45 AM
Insurance - When is enough enough Poprivet Insurance & Claims 6 06-27-2007 07:29 PM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
Part Time vs Full Time (Days/Year) InsideOut Community Polls 30 10-23-2005 09:43 AM
