Old 09-30-2020, 04:00 PM   #1
Jasper , Georgia
End pulled off HDMI cable
Hello everybody, I need some help. I have a 2017 Flying Cloud 23FB. The other day I noticed a cable hanging down from the television. When I looked closer I thought the HDMI cable had come unplugged, what had happened was the meter end of the cable had pulled off and was still in the television and the end of the cable was all of the wires that go into the plug. There is no way to repair this so I started looking to replace it, You likely know what I found, once it goes into the wall it disappears and I have no way to trace it. Does anyone know where this cable terminated and how it can be replaced? I have seen a lot of wisdom on the forum so I hope someone can help me. Thanks!
Scomor is offline   Reply With Quote
Old 09-30-2020, 04:10 PM   #2
2019 30' Classic
2021 Atlas
Charlotte , North Carolina
I don’t know about the FC but I have one HDMI going to the TV from an HDMI switch in the AV area where a blue-ray is. It allows a single HDMI to transmit antenna or Blue-ray or and aux input.
My guess is the other end of the cable is where your Blu-ray or VCR or DVD or whatever is. I have to take apart the little house they built for all that and it is in there with every other wire ever conceived.
LilPeanut is offline   Reply With Quote
Old 09-30-2020, 04:20 PM   #3
2018 25' International
Slidell , Louisiana
It terminates under the dvd player on the signal splitter the sends the DVD signal to both TVs. I have doubts about being able to pull it out and a new one in but IDK.
The DVD player console has two screws hidden by plastic plugs on the side you can access. Remove them and the whole thing comes out. It is easier than trying to get to the cable and splitter through the DVD opening.
Old 10-01-2020, 06:53 AM   #4
Jasper , Georgia
HDMI cable issue
Thanks for the support, I have decided that to re-run that cable is beyond what I want to do but I think I found a work around. There is a HDMI terminal block that is very inexpensive. I’ll have to cut the end off and strip back the jacket then each small wire goes into it’s own terminal block. It will be a bit fiddley but beats taking my AS apart! I will send a link to this block on another post I case it helps someone else who is having this problem. Thanks again!
Old 10-01-2020, 07:09 AM   #5
Slidell , Louisiana
Nice solution!
Old 10-01-2020, 06:13 PM   #6
mwodzinski's Avatar
2017 23' International
Winter Park , Florida
On a 23FB, the HDMI cable goes from behind the radio receiver in the upper cabinet above the dinette to the wall behind bedroom TV. I think the cable is routed across the ceiling through multiple frame ribs. If the HDMI connector broke off, which happened to me, then you can purchase a HDMI connector repair kit and replace the missing connector. The kits are available on Amazon. There are both solderless and solder kits. I prefer the solder type since the fix is more permanent. If your soldering technique is rusty then I would find a friend with electrical skills. You will need a jeweler’s screwdriver for the solderless connector terminal block type. The cable is a 1-to-1 connection (Pin 1 to Pin 1 and so on). I used a long jumper wire and a multi-meter to find and check the wires. I used a female HDMI solderless connector to use the jumper wire on the good end so I could “beep-out” each wire (using continuity beep function on my multimeter). This is a tedious job since there are 19 wires in an HDMI cable in an awkward location so a very patient person needs to do this repair.
If you want to replace the cable, it will be a big job since you will need to remove a lot of panels and cabinets. There is no way to use the old cable to pull through a new one (there are too many tight turns. If you decide to replace the cable then I would replace it with a 4K HDMI cable. You’re probably not going to go that route - it would be a labor intensive repair best done during a restoration. Airstream wires the RV before they put in the cabinets and interior panels. Running a new cable would be very difficult.
As a short term fix, you can route a long HDMI cable from the blu-ray player out of the upper cabinet across the “sliding door” track and back to the TV. As another short term fix, you can also move the blu-ray player to the bedroom and run a short HDMI cable to the TV. Most standard 23FB’s have only one TV in the bedroom.
FYI, I upgraded my 23FB serenity to 4K, 5.1 stereo and a 43” 4K monitor in the bedroom split to a 23” computer monitor in the dinette. I’m a traveling IT engineer/consultant and I need my computer, DVR and Satellite TV. This was a very big job but now I have my mobile home theater and computer work station.
mwodzinski is offline   Reply With Quote
Old 10-01-2020, 07:03 PM   #7
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
It can be repaired, I had that problem the trailer was delivered with a damaged plug, I was too green to have any idea to check this. Airstream wanted to open up the ceiling to replace the cable, on a new trailer it was my last option, I honestly may have survived without the TV. My brother-in-law an electrical engineer fixed it tracing, matching and soldering sets of wires I think there were 21 sets of them, complicating the process was the new HDMI plugs colored wires didn’t match up to the colored wires of the existing cable, but he did match them. So if you know someone with these skills it can be done. The new HDMI PLUG HAS A 45degree downward bend so it can’t happen again . All works perfectly. Sorry for your problem.
Silvr_Bullet is offline   Reply With Quote
Old 10-01-2020, 07:18 PM   #8
2020 25' Globetrotter
Los Gatos , California
My 16 Bambi new came with same issue. I found that the wire was actually a short run to just outside wall. Just replaced it
2016 450 GL, EazLift Elite 1000
Renogy 400 watts and 100 suitcase, 30/100MPPT, Victron 712, 6V Duracells
Honda 2200 propane, Weboost Drive X, EEZ TMS
Traded in 2016 Sport 16, 2019 Sport 22
As they say, third AS is what to buy first
Garfish is offline   Reply With Quote
Old 10-02-2020, 10:29 AM   #9
​2020 Atlas​
Carmel , Indiana
I went to wireless hdmi. throw the cable away. Under $200 at Best Buy
skweaver is offline   Reply With Quote
Old 10-02-2020, 10:44 AM   #10
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Wiresless HDMI?! 🤯
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 10-02-2020, 11:15 AM   #11
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
I am not an electrical engineer but if you use the same brand HDMI cable as the broken one, for the repair, the wire colors will match, no tracing necessary. I copied the reply below from another similar thread I responded to recently.
I had to replace the HDMI cable connector that plugs into the TV. Is the unused cable the same brand? If it is, then the wire colors will match, and you could cut off and then solder the end from the unused cable onto the broken cable end.
However the end we replaced was very accessible, at the TV. You may be able to gently pull the broken cable out for better access? Mine had lots of slack that had been stuffed into the wall. If no slack is available it might be harder to solder.
Good luck
Hiho Silver is offline   Reply With Quote
Old 10-02-2020, 02:22 PM   #12
2017 16' Sport
N/A , N/A
Good luck
Probably if you get the same brand used by Airstream. In my case I wouldn’t have wanted that, the one I replaced it with has a 90 degree downward articulating elbow that did not duplicate the cheap one used by Airstream .
Old 10-02-2020, 03:34 PM   #13
UncleBad's Avatar
2018 27' Tommy Bahama
Marana , Arizona
Our HDMI cable to the front TV in our 27FB became damaged during panel repair for hail damage last year. I tried repairing with the HDMI cable end with one available on Amazon. Several hours and cuss words later I ended up using a wireless HDMI solution as well. Works great!!
Used this:
https://amzn.to/33mDfhA
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 10-02-2020, 07:59 PM   #14
I used this and the HDMI cable from the blue ray player, so the wire colors would match. Then replaced blue ray player cable with the new cable I purchased
Old 04-14-2021, 07:40 PM   #15
paiceman's Avatar
Upper St Clair , Pennsylvania
When we got our 2020 FC we had no cable etc. I found out nothing was hooked up to outside connections or to the back TV. Back to dealer who fixed the issue and ran cables thru the ceiling ductwork. I can’t see or find and holes or issues and it all works fine. Just today while on a trip the HDMI end ripped out of the TV in the dinette area. So reading all this I might take it back to the same dealer or go wireless.
2020 28' Twin Flying Cloud
2017 30' Twin Classic-(Our 6th Airstream)
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator
Old 09-03-2021, 11:45 AM   #16
2018 25' Flying Cloud
Marana , Arizona
What HDMI cord did you plug into the transmitter end of your wireless setup?
Rich & Mary
Marana, AZ
2018 25’ FC/FB
Zardoz is offline   Reply With Quote
Old 04-30-2023, 05:00 PM   #17
2015 19' Flying Cloud
Columbus , Ohio
HDMI cord broke at TV
Better late than never. I had the same thing happen to me last year. I upgraded my system so I would no longer need to use the HDMI cord that was there. Head over to Best Buy or order on Amazon a Wireless Display HDMI Extender. Basically, you plug the dvd player into a box that wireless transmits the video to the TV. Both the TV and the DVD player will hook up to a mini box the work together wireless. no drag, no delay. always a perfect picture. It's amazing. cost was around $150-$200 I think. I will attach pictures of my setup and the box brand i bought. Good luck!!
ID:	430931   Click image for larger version
ID:	430933   Click image for larger version
HighwayVegan is offline   Reply With Quote
Old 04-30-2023, 05:07 PM   #18
Columbus , Ohio
I did and it worked great!! Thank you for sharing this information. I posted and included pictures. You saves my life!!
Broken HDMI cable end skweaver Electronics & Connectivity 4 09-03-2021 04:28 PM
Broken HDMI cable end skweaver Audio, Video & TV 4 07-20-2021 09:05 PM
HDMI Cable End Replacement Tater Audio, Video & TV 5 09-04-2014 02:36 PM
HDMI Splitter Cable GerryH Audio, Video & TV 1 12-14-2011 12:26 PM
HDMI cable for 20' Flying Cloud mistermcfrug Audio, Video & TV 18 02-09-2010 03:22 PM
