05-16-2017, 08:54 PM
2016 26' Flying Cloud
Southlake
Disappointed in DISH TV
We have been using DISH on the road for a little over a year and have been happy with it until this trip. We have the Winegard X2 antenna and were only getting some of our channels. I called DISH and was told that they do not offer support unless the antenna is connected directly to the receiver. What is the SAT connection to be used for then? I called Winegard and after going through extensive troubleshooting, I was told that the antenna was working properly and that the problem is with the DISH programming. I called DISH back, told them what Winegard said and they wouldn't budge. Now that I am home, I plan to see if connecting directly to the receiver makes a difference. If it does, I will have to figure out a direct connection without leaving the door open or cutting a hole in a window screen. I guess what really irritates me is that I purchased the receiver and antenna directly from DISH and only now did I get this story.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
05-16-2017, 09:31 PM
2002 30' Classic S/O
Fleming Island
Sorry, I'm confused. How is your antenna connected if not direct to the receiver (through a cable in the Airstream)?
Al
05-17-2017, 06:03 AM
Lakes Region
, New Hampshire
I would guess they mean without connectors in between, one cable, this would be to guarantee against signal loss from bad feed thru connectors.
Not knowing the dish system specifically, I might guess that your location played a part, as you've been happy until that location, the X2 being fully automatic I would be curious to see what the peak signal was that it stopped on, were all streams being captured or did it lock off center? If on center, was your location poor enough that the sides were lost?
How did it perform when you were back home, as normal?
05-17-2017, 06:10 AM
Alamo Heights
Just as a troubleshooting step you can temporarily run the cable in through the door to a TV directly from the antenna and test the service that way, thereby getting the dish rep to move to the next section of his script.
— David
05-17-2017, 08:17 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
The above statement is 100% correct. When debugging, Dish wants to start with as few "variables" as possible. If your Dish works when connected directly to your Wally (or whatever receiver you have) but not when connected to the external satellite connection, then the problem is likely in the wiring inside the Airstream. Once Dish determines that the system does not work when connected directly to the receiver, then you move on to the next level which usually means a new dish or receiver. We had a problem with a bad satellite dish that once diagnosed with a direct connection to the receiver resulted in Dish sending us a new satellite dish which worked perfectly.
Bob Martel
WBCCI# 5766
05-17-2017, 08:47 AM
Tavares
Our Dish system purchased this year (Windgard Playmaker and Wally) has worked well.
The only time I only get 'some' channels is if I don't have line of sight to all three satellite positions Dish uses (think it is 129, 119 and 109 degrees, from memory.). I connect through the SAT input on my '16 FC direct to the back of the Wally.
Sounds like we need more info on your issue, as above. Signal loss could be anything in the connections, but it would affect 'all' channnels, not just some.
On the connections:
Does everything work satisfactorily connecting 'directly' from antenna to the Wally (as in, though the door)?
Are your connections at the SAT input clean and tight?
Have you tried a new coax cable?
Have you verified the coax at the electronics cabinet is making good contact to the Wally?
On the signal side:
When you only get partial channnels, how is your line of sight?
Have you checked line of sight with an IPhone App like Sat Finder Lite or similar?
Is the Winegard antenna physically aligned (coax jack pointing North) correctly?
Which channels, specifically, are you 'missing'?
Have you run the alignment diagnostics and selected the correct initial starting location?
What is your typical signal strength value when things are working normally?
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
05-17-2017, 09:24 AM
Southlake
I plan on doing all these things after I decompress from 4 long days on the road.
On the plus side, the AS and the new tow vehicle worked flawlessly. From 20 deg in Bryce Canyon to 96 deg in west Texas. Even the GYM's survived the 3,000 miles!
Equalizer Hitch
05-17-2017, 10:33 AM
Fleming Island
You could always do what I do with DirecTV. When they ask me to do something that I know won't make a difference, I just tell them I did it.
But I like the idea of obstructions. I had the same problem a couple of weeks ago. I attributed it to not getting one of the sats.
Al
05-17-2017, 10:57 AM
1965 24' Tradewind
Henderson
, Nevada
If you don't hit all three satellites you get limited channels
Llando is correct ( above )
If you don't hit all three satellites you get limited channels. Happens to me in a campground in AZ..I get everything but local channels.
05-17-2017, 11:11 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
We had direct and a moveable antenna, then we had direct and a fixed antenna on a Newmar motorhome. We had all kinds of issues with the moveable antenna running thru the AS connections, if I ran the antenna directly to the Direct receiver no issue.
Now we have another AS and we have Dish. We have the traveler mounted on the roof, wired directly to the Dish 211z receiver - so far (as with anything to do with RVing) we have no issues, except trying to pick up a signal thru pine trees, other trees not much of an issue.
Good luck.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
05-17-2017, 12:47 PM
2017 23' Flying Cloud
Lakeport
, Michigan
The Pathway X2 likes to be perfectly level to do a scan. I've had it find only two of the three birds if it's not level.
05-17-2017, 01:33 PM
Long time owner
2004 25' Classic
1974 25' Tradewind
1970 21' Globetrotter
1975 26' Argosy 26
Forrest City
, Arkansas
I have DirecTV and have had a similar problem. It will not work when connected to the AS. I have to run the cable thru the door and it works fine. Of course, when the AS is connected to cable everything works so there is "something" about the connection not being direct.
05-17-2017, 02:07 PM
Tampa
Don't assume there's one cable running from the receiver to the access panel. There may be a switch, barrels, bad crimps and a bunch of things you can't see.
I had a "cable" connection with NO slack, and when I tugged on it the connector came off in my hand.
Good!
My advice is to only change one thing at a time. First, run a coax through the door. Then, work from there, if successful.
05-17-2017, 04:02 PM
Fleming Island
Good!
I'd suggest that the first test should be in original hookup since it is possible that there were obstructions in the path, or the antenna was not level. It might just work.
My original post was assuming that the system had been working for a year, and that the newer trailers had separate cable and satellite cables. Shame on Airstream if they put a splice in a satellite cable. But maybe they came to the end of a roll and didn't want to waste 10' of cable .
Also, any damage to the cable could create a frequency-selective loss that might affect reception on one transponder and not on others.
Al
05-17-2017, 04:57 PM
Argyle
We need a Glossary of terms particular to Airstream. What the heck is a "Wally"?
05-17-2017, 05:16 PM
Lakeport
, Michigan
Wally is a very basic solo Dish receiver commonly used with RV Dish antennas.
05-18-2017, 05:42 PM
Argyle
Thank you, so much, Motown.Appreciate your defining.
