Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 10-08-2017, 02:52 PM   #1
2017 19' International
Tallahassee , Florida
Digital video ... how to play from my iPhone
I'd like to play videos from my iPhone, but ... can't figure out how this is done.
Can play a DVD via the DVD player ... works great.
But the iPhone ... a mystery.
There are USP ports all over the place — this is in a 2017 19-footer — but none of the one's I've tried (near the TV and near the DVD player) — are the secret path.
The TV "source" selection shows TV, two HDMI options, AV and component.
None of these selections are the key.
What's up with digital video?
WhereStream is offline   Reply With Quote
Old 10-08-2017, 03:01 PM   #2
Open field , Idaho
There are a couple ways you could do it. Apple makes a cable to connect to to HDMI ports via either style connection an iPhone would have...newer ones would be HDMI to Lightning, older is 30 pin to HDMI.
https://www.amazon.com/Apple-Lightni.../dp/B009WHV3BM
https://www.amazon.com/1080P-Adapter.../dp/B00A6Q596I
Another method would be to get an Apple TV, it connects to the HDMI port either directly on the TV or through the DVD player. With it you can Air Play from your phone to the Apple TV to display anything you have on the phone.
Brief guide to how to air play to an Apple TV
https://support.apple.com/en-us/HT204289
MrArrowhead is offline   Reply With Quote
Old 10-08-2017, 03:02 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Check with Apple customer service not sure if you need a router or not. I do it at home with my I Phone as the control but the TV is hooked via cable to my router and i am viewing on that cable input htmi 2
2004 Excursion 4x4
Old 10-08-2017, 03:12 PM   #4
1979 23' Safari
Wayland , New York
Depends on the video. Videos you took on the phone or playing through app or video streaming service?
Apple TV plugged into one of the HDMI ports. You can cast from your phone. You'll need a wifi router to connect through. Hootoo makes nice small travel routers.
You can also get cables to go from phone to hdmi port on the tv.
Old 10-08-2017, 03:23 PM   #5
These are movies on Amazon's app.
I can play them in the house, using an Apple TV device ... for some reason I thought the Airstream was set up to play videos without the Apple TV.
Old 10-08-2017, 03:59 PM   #6
2016 28' Flying Cloud
Brandenburg , Kentucky
Chromecast
Have you looked at Chromecast? I have an older Chromecast unit and I can "cast" video from my iPhone to my Samsung smart TV. You have to load Googles Chrome web browser on to your iPhone. You'll also need to be connected to a network. I have a router in my AS, so it connects that way. I'm not familiar with the newer Chromecast devices and how they are configured..
Check this link out.
https://store.google.com/product/chromecast_2015
And of course look at YouTube for How-to's on Chromecast
Tsunami-v2 is offline   Reply With Quote
Old 10-08-2017, 04:10 PM   #7
Open field , Idaho
You can use an Apple to HDMI connection to view any thing on your phone...works like screen share. If your phone is newer it would be the same lighting connection on one end and then an HDMI female connection on the other end. Older phone with the 30 pin connector is available as well. Then just get how ever long of an HDMI cable that you would like to connect into the TV or the DVD player.
Or if you have wifi set up in your trailer you can use your Apple TV just like you would at home with the Apple TV plugged into the TV HDMI.
Old 10-08-2017, 04:42 PM   #8
1979 23' Safari
Wayland , New York
The problem with the chromecast is that it needs an actual internet connection. More than just a ad hock wifi connection between the phone and chromecast via a local wifi router. While at home this may work but in campgrounds or boondocking it's not helpful. There is a workaround but it's a pain and you have to do it each time you want to use the chromecast. This comes into play with video you have saved locally. Since you're more concerned with streaming with a good wifi internet connection available, an Apple TV, Amazon fire stick, or roku should work.
Old 10-09-2017, 10:55 AM   #9
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
i concur.
Or the lighting to HDMI also works.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 10-11-2017, 02:31 PM   #10
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
Install an Apple TV then use Airplay -
works great and no network needed.
Here is our video on youtube that shows how to do it https://youtu.be/aoBdtzwmM1g
Our Website: https://airstreamnerds.com/
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 10-12-2017, 04:40 AM   #11
Thanks, AStreamNerds, I'll check out the video.
I have an Apple TV box in the house, but ... I thought it connected via wifi to our router, and any video I played from my phone went to router first (hey, I'm no expert in these things!).
I want to see what you've worked out.
Old 10-12-2017, 05:38 AM   #12
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I use an Apple TV and the Apple Lightning/HDMI connector. I can stream AppleTV Netflix or HBONow from its apps via iPad hotspot(on VZ unlimited) from the Apple TV but because it uses so much data my 15g hotspot limit is reached before the monthly cycle ends so I end up using the iPad connected directly to the the TV via the Lighnting adapter. It's much less hassle than using the Apple TV. I rarely use my 3rd gen Apple TV now in the Airstream and because the iPad has cellular and is on the VZ unlimited plan its not restrained by the 15g hotspot limit.
Kelvin
Old 11-25-2018, 10:32 AM   #13
369goose's Avatar
2014 25' Flying Cloud
1987 29' Sovereign
1978 31' Sovereign
Tampa Bay , Florida
Easiest way to watch TV (sports) on AS Damsung Smart TV’s now that everyone has gone
In the “old days” we’d been fortunate to get some channels over the air in our Airstream. However now that most providers have gone digital what’s the best way, least amount of devices, etc to make the Samsung TV’ in our trailers useful for anything other than dvds?
What would I need to play games on my iPhone but watch on one of the Airstream TV’s?
369goose is offline   Reply With Quote
Old 02-08-2019, 11:49 AM   #14
We recently transitioned from hardwire (HDMI) to wireless connection and thought we'd share.
Prior to traveling in our AS we like to download our recorded DirecTv programming from our home DVR to our iPhones and iPad. We then use a Apple A/V adapter and HDMI cable to watch this content using the mirroring mode. This works pretty well but we got tired of having to get up to use the controls and started looking for a wireless option.
We now use an Apple TV in our AS to wirelessly mirror our Apple devices (no internet required) to the TV. We had talked to a representative at the Apple Store and from Best Buy. Neither seemed sure it would work without internet for authentication. The Best Buy rep suggested getting the Apple TV and if it didn't do what we wanted they would take it back with full refund. The Apple TV works very well. We just connect it to the TV with HDMI cable, power it up, and set Apple device to mirror mode.
rgarza348 is offline   Reply With Quote
Old 02-08-2019, 02:00 PM   #15
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
I used to watch movies on iTunes by connecting my iPhone to the TV using the apple lightening to HDMI adaptor. This no longer works as Apple now will not let the phone play content on a connected device. I guess they think you are showing movies to the public or other such foolishness. Now I have to do this via Apple TV, or by mirroring the phone (AirPlay) to the Apple TV.
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 02-09-2019, 02:20 PM   #16
HowieE's Avatar
Images: 12
I have an Apple TV box and Directv. I currently use that equipment to mirror YouTube to my home tv. Would you go into more detail as how you get programs from your Directv DVR to your I Phone?
2004 Excursion 4x4
Old 02-10-2019, 12:34 AM   #17
Use the DirecTV app to download saved programming from your DVR to mobile device. This allows you to view the programming from anywhere within 30 days of the download. Simply mirror to your Apple TV when you want to start watching.
Old 02-10-2019, 06:37 AM   #18
Thanks, rgarza, this is good to know.
I was told an Internet connection (or at least a wifi router) was required.
I've got an Apple TV thing that we really don't need with our new television in the home. I may pull it out, hook it to the Airstream's Samsung and see if it works.
Old 02-10-2019, 06:59 AM   #19
Old 02-10-2019, 08:05 AM   #20
nryn's Avatar
2019 27' Globetrotter
Driftless Area , Wisconsin
I'm not sure this is true. I connect both iPads and iPhones to TVs and monitors all the time with HDMI adapters and play content of all sorts.
I've noticed that in some cases iTunes movie content can be downloaded in a format or resolution (HDR 4K I think) that is not compatible with some televisions, so those movies won't play on those televisions. And I've also noticed that some televisions (and perhaps some adapters, not sure) have some mismatch in HDMI spec so that the DCP (digital content protection) handshaking that goes on reports some sort of error. I've always assumed that this happens when there are older televisions (with HDMI, but not recent HDMI) in the mix. And I've abandoned all non-Apple HDMI adapters (most of which seem to not work reliably anyway).
When Apple moved to USB-C on MacBooks, MacBook Pros, and now their latest iPad things got a little wonky. I found on my MacBook Pro that it mattered somewhat whether you plugged in the adapter first, then connected the cable between the adapter and the TV. They seem to have gotten that sorted out by now but for a while there it definitely wasn't the simple user experience that I'm accustomed to with Apple equipment.
But we play movies and TV from iOS devices all the time through HDMI adapters. In fact a retractable HDMI cable and a lightning-HDMI adapter are now a standard part of our travel kit (they stay in our suitcase).
nryn is offline   Reply With Quote
Wheel bearing play: Is this too loose? (video) amm3824 Axles 7 09-04-2014 09:01 PM
