Old 09-13-2018, 05:24 PM   #1
2018 23' International
Guilford , Connecticut
Clarion fell in
I may have inadvertently posted this in the wrong sub-forum (darn newbie) so I'll try again...
So as we were driving home our spanking new 23FB the bouncing around caused the Clarion stereo, which mounts to the face of an upper cabinet to detach from its metal "shroud" and fall inside the cabinet, to which there is apparently no access, aside from the cutout for the stereo. With some work we were able to fish it back out through the opening, pull out the "shroud" and re-install. The whole thing rocks up and down in the cutout due to it being fairly heavy and having no support whatsoever aside from the cutout itself, and this in turn causes the plastic bezel to keep popping off.
I'm thinking I may try building up some kind of a shelf to support it from underneath, inside the cabinet, by putting strips through the cutout and laminating them up to the appropriate height. Anyone with similar issues with the stereo have any good fixes?
Pop
Pop & Mimms - because our grandchildren say so
2018 23FB International Serenity "Pimm's Cup"
2019 Tundra
Pimms is offline   Reply With Quote
Old 09-13-2018, 05:45 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Not sure on this one. Any pic’s. They might help....
Old 09-20-2018, 08:30 PM   #3
2019 25' International
Providence , Rhode Island
Make sure the sleeve "cutouts" interlock behind the mounting hole...sounds like that tabs were not properly pressed to "lock" the sleeve into the support structure. No shelf needed, the sleeve will free suspend the radio body just like when installed in a car!
Watch this video:
What i describe starts at time index 3:50/6:23
LMK how it goes.
Chris
kittmaster is offline   Reply With Quote
Old 09-22-2018, 07:00 AM   #4
Thanks for researching this and posting the YouTube, Chris. The metal sleeve was slightly loose in the cabinet cutout, even with the retaining tabs bent over. I drilled holes in the sleeve and drove small flathead screws through the sleeve into the sides of the cabinet cutout. Now it is very secure. I also inserted thin plastic strips behind the two side locks in the sleeve that “click” into the receiver that will keep them in place. While at it, with the receiver removed, I also bundled the various wires and cables into flex tubing to provide better chafe protection at the point where they went out the rear of the cabinet and trough the inner skin. All good now.
Pop
2019 Tundra
Old 09-22-2018, 07:10 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
Our itty-bitty Sony did the same thing 15yrs ago...😳...not locked in.
also with the no access housing. Consistency? 😂
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 09-22-2018, 11:02 AM   #6
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
EDIT: Sounds like you got it handled. Kudos.
If you remove a speaker from underneath that should give you some access to the mounting area. But for now, given it's a 2018, I would opt for a warranty fix...making sure they open the whole thing up and properly secure the chassis.
pcskier is offline   Reply With Quote
Old 09-22-2018, 03:23 PM   #7
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
I solved the problem with a jigsaw. I cut a larger opening and replaced the clarion with a proper double DIN touch screen system with Apple car play and other goodies
ID:	323328   Click image for larger version
wulfraat is offline   Reply With Quote
2015 International / Clarion / Samsung Questions cbrittan Audio, Video & TV 15 03-07-2016 08:24 AM
Clarion Sound System on Classic 2015 TonyGuyer 2011 - 2015 Classic (all lengths) 17 08-09-2015 02:43 PM
FREE: Clarion M502 and 2 speakers Gsmblue Audio, Video & TV 6 05-21-2015 11:05 PM
Binning the Clarion M502 Gsmblue Audio, Video & TV 9 04-07-2015 12:04 AM
Clarion, Pa. Autumn Leaf Festival 2014 pintoman Other Rallies & Events 1 09-13-2014 08:04 AM
