RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-23-2021, 06:51 PM   #1
2019 28' International
Murphy , Texas
Auto Programing TVí
19 International signature 28í. I used auto program to receive local channels. The TV in main area gets almost 50 plus channels and the TV in bedroom only gets 25 channels. I tried several times to program the TV but same occurs. They should get same Chanelís since we are using the DTV antenna. Any thoughts??
Jkreis is offline   Reply With Quote
Old 01-23-2021, 07:55 PM   #2
2019 25' International
Providence , Rhode Island
I assume they are both set to "air" and not "cable" when you are doing the scan?
kittmaster is offline   Reply With Quote
Old 01-23-2021, 08:11 PM   #3
2018 25' International
Slidell , Louisiana
If everything else is set the same, then I'd look for a poor connector with significant signal loss either at the splitter after the amplifier or back to the bedroom. A cable or satellite service person could find the issue but you may get a cable signal strength meter and try yourself.
Old 01-23-2021, 10:50 PM   #4
1988 32' Excella
Robbinsville , New Jersey
In my trailer antenna goes to main area then to bedroom. It's possible extra wire length could cause loss of marginal channels.
Old 01-24-2021, 07:22 AM   #5
Slidell , Louisiana
If the ends are done correctly so the impedance is matched, short cable runs have minimal losses and attenuation compared to the connectors. Look at the connectors first.
Old 01-24-2021, 08:17 AM   #6
Took the words right out of my mouth.
The other thing also could be the QCAM settings in the lesser TV. Not sure if they can be adjusted or not.
I do know that both of my TVs tune identically from what we've seen in bad areas......so I also suspect a loose or bad cable end may be suspect here.
Old 01-24-2021, 08:36 AM   #7
2020 23' Flying Cloud
Sebastian , Florida
Are they the same brand/model TV?
A quick test would be to swap the antenna leads and scan again, to see if the living room set loses channels in the bedroom or vice versa.
I don’t know how long your antenna leads are, or how the TV’s are mounted. On ours, four screws releases the sett from the mounting arm.
-Don
(That man in that tiny can)
(Same man, Bigger can)
GetawA-S is offline   Reply With Quote
Old 01-24-2021, 09:46 AM   #8
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Jkreis, Iím with BayouBiker and kittmaster on this.
While camping last summer at a site with cable our picture was terrible. The campground manager came by with his Fluke meter to test the signal at the pedestal. It was within specs so he put his meter on end going to the TV. It was well outside specs. He had me run a cable direct from the pedestal to the TV - perfect picture.
That tells us the problem is inside the trailer. At some point Iíll try and replace the cables and connectors inside the trailer. I suspect this is also why we have poor over the air reception with the amp turned on.
Itís a shame Airstream doesnít spend an extra dime on the quality of cable, connectors and installation since once the furniture goes in, you cannot service it.
You could experiment by running a tested good cable from the coax connection in the front to the bedroom TV and re-run the scan. If it improves, itís cable or connectors.
Good luck and let us know what you found!
Jeff
2019 27í Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 01-24-2021, 10:48 AM   #9
Slidell , Louisiana
Quality of cable and connectors are generally not the issue. It could be the initial connection quality or the durability due to vibration on the road or use damage. Let's not be too quick to blame Airstream unless we have the facts that point to component selection, cable route design or installation.
Old 01-24-2021, 11:17 AM   #10
jeffmc306's Avatar
McHenry , Illinois
Brian, I’ll let you know what I find once I get into the wall and find the problem. I spent many hours wiring racks in data centers and know how easy it is to miss a connection. That’s why you test each after crimping / connecting.
I really doubt Airstream does a end to end cable test before they install the furniture. If they did I’d feel much better about what’s in the walls. I’ll be glad to say it’s just a loose connection if that’s what I find.
2018 FC23FB
WBCCI# 10258
RETIRED!
Trouble programing the thermostat ASaddiction 2011 - 2015 International 7 04-12-2016 02:59 PM
Allison auto transmission O/D lockout davidz71 Tow Vehicles 0 01-20-2003 11:28 AM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 06:49 AM
Auto Battery problems.... kzener40 Airstream Motorhome Forums 10 08-05-2002 07:37 PM
Auto trans temps chart FrankR Mechanics Corner - Engines, Transmission & More... 9 05-05-2002 09:42 AM
