03-06-2021, 10:45 AM
1973 25' Tradewind
Fort Collins
Anyone ever seen one of these audio connectors?
I recently purchased a 1973 Tradewind and noticed this cable/connector under the control panel in the front. I've owned a few vintage Airstreams but have never seen one of these. Does anyone know what it is? I assumed it's an old headphone jack for the speakers but tried it and it doesn't work. Curious if anyone has any expertise with this! Thanks in advance!
03-06-2021, 10:49 AM
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas
, USA
That looks like an old style AM radio antenna connector (automotive).
03-06-2021, 10:57 AM
Tampa
+1 Radio coax.
03-06-2021, 11:26 AM
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver
Definitely for antenna. You could possibly repurpose it for wifi or HD broadcast TV.
03-06-2021, 02:46 PM
Grace the Airstream
2020 27' Globetrotter
Powhatan
, Virginia
AM/FM automotive antenna.
03-06-2021, 04:12 PM
1976 Argosy 28
Buford
, Georgia
+1, standard issue...
03-06-2021, 04:13 PM
Slide Out Society #001
2007 30' Classic S/O
Somewhere
, South Carolina
That’s a cable end for listening to Wolfman Jack!
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
03-07-2021, 11:04 AM
2017 23' Flying Cloud
Lakeport
, Michigan
Motorola antenna connector, common with car stereo equipment. Think AM/FM antenna.
03-07-2021, 11:47 AM
Bluffton
, South Carolina
That makes me smile 😊
03-07-2021, 12:02 PM
1973 25' Tradewind
Fort Collins
Thanks all for the replies!
I'm assuming it was plugged into the original radio that used to be mounted under the control panel?
What can I use it for now? Can I repurpose it/change it's function? I'd like to be able to use the speakers in my Airstream.
03-07-2021, 12:19 PM
1972 31' Sovereign
Dry Branch
, Georgia
speakers
Your speaker wire ends should be near the same area as the antenna wire.
I still like my FM radio
03-07-2021, 12:25 PM
2019 27' International
Rogers
, Arkansas
I Can Still Hear Him Howl
Although I have not heard or thought of him/ his voice in years, it comes back immediately
03-07-2021, 12:43 PM
1988 32' Excella
Robbinsville
, New Jersey
No doubt
What can I use it for now? I'd like to be able to use the speakers in my Airstream.
Install a new radio with blue tooth and aux in. Can stream music from phone, get blue tooth adapter for TV or wire to TV
Maybe use for TV antenna or WIFI antenna, might not work, poor design for this.
03-07-2021, 12:51 PM
1972 31' Sovereign
Dry Branch
, Georgia
Is the actual antenna still on the outside of trailer that is the only thing it goes to
03-08-2021, 10:05 AM
1973 25' Tradewind
Fort Collins
Yep, there's an antenna mounted to the roof. So I'm assuming it's connected to that. Should I keep it? I'm trying to figure out a way to use my speakers for music etc, but don't necessarily want an old school am/fm radio.
03-08-2021, 10:07 AM
1973 25' Tradewind
Fort Collins
No doubt
Thanks! If I install a new radio, will I need to find one that would plug into that cable that's coming out of the control panel? Should I keep the antenna that's currently mounted to the top of the Airstream? Would a new radio play directly through the speakers?
03-08-2021, 10:08 AM
1973 25' Tradewind
Fort Collins
Thanks! I don't see any speaker wire ends... Hm...
03-09-2021, 11:06 AM
1988 32' Excella
Robbinsville
, New Jersey
I haven't looked at new radios for quite a while so I don't know if that is still a standard connector or not. If you get a radio with that plug your current antenna should work. You need to find and connect the speaker wires for them to work the wires were there when your trailer was built, they didn't have wireless speakers 40+ years ago.
03-10-2021, 06:36 AM
1976 Argosy 28
Buford
, Georgia
That is still the standard. There was a time that some car manufactures decided to change the game a bit, but it didn't last long..
John
03-10-2021, 09:24 AM
1973 25' Tradewind
Fort Collins
Thanks for the help! That makes sense. So the speaker wires should've been coming out of that same spot as they would've been connected to the original radio? How would a new radio get power? Does that cable/connector that's there also supply power?
