Old 08-26-2018, 10:25 AM   #1
2014 19' Flying Cloud
Livingston , Texas
Antenna replacement
I have a 2014 19’ FC with a batwing tv antenna and I would like to replace it with a more modern and efficient model. Anyone have any suggestion?
Munchie is offline   Reply With Quote
Old 08-26-2018, 11:06 AM   #2
2007 27' Classic FB
Ridgefield , Washington
Images: 11
We wanted to replace ours when we were at Jackson Center last summer. The advice from them was to leave it as is. Apparently the opinion is the Winegard batwing is better than anything you could replace it with.
John
Woosch is offline   Reply With Quote
Old 08-26-2018, 12:51 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Better and more efficient = larger antenna on a taller mast. Yes, you can do this. Is that *really* what you want to have on the top of your trailer? I'm betting not. If you *are* after something big, chime in and various folks among the group can supply details.
As mentioned above, *any* of the new / small / low profile antennas will do a worse job than what you now have in terms of picking up signals. They will be far more cute.
Old 08-26-2018, 02:45 PM   #4
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I installed the new King Jack antenna, the shorty OA8200, and can state the following; "reception is no different, there is no risk of forgetting to crank down the mast, and it is easier to find the stations when using the built-in signal meter." The process was straight forward and it freed up terrain for solar panels.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 08-26-2018, 11:52 PM   #5
2007 22' International CCD
Yup. I’m going to one to have more room for solar panels and ham radio antennae on the roof.
Old 08-27-2018, 06:33 AM   #6
Half a Rivet Short
2022 Interstate 24X
Hi
Having played "who can get what station" a few times when bored at remote campsites .... the old crank up's always win.
Old 08-27-2018, 10:10 PM   #7
Antenna replacement
We rarely, if ever use the television. I think it got used two days in the last 5 years so far, when the weather was too ugly to risk traveling in West Texas. Plugged in to cable tv at the KOA and watched weather reports, mostly.
Old 08-27-2018, 10:21 PM   #8
AFTER TAXES's Avatar
1964 22' Safari
1993 25' Excella
Flagler Beach , Florida
wow, replaced with the same, but with newer model batwing
works great !
AFTER TAXES is offline   Reply With Quote
Old 08-28-2018, 01:10 AM   #9
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
Do NOT change to the round "flying saucer" omnidirectional antennas used on new Airstreams. They do NOT pick up nearly as many channels in low signal areas as the earlier antennas that could be turned (and raised higher above the roof) to maximize signal strength. It is an engineering fact that an an omnidirectional antenna will never have the same "signal gain" as a directional antenna.
The ONLY advantages of the flying saucers are that you cannot forget to lower them and they take up less space on the roof. I suspect these are the reasons Airstream changed to them, NOT because they work better.
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
Old 08-28-2018, 08:54 AM   #10
Livingston , Texas
Thank you all for your insight. You have helped me decide to stay status quo.
Old 08-28-2018, 09:02 AM   #11
2018 26' Flying Cloud
Oriental , North Carolina
I started a thread recently about reception, which only got one response. I agree with Joe that the new, low profile omnidirectional antennas do not work all that well. I don't think AS is really concerned about giving us the absolute best in antennas.
Captn.Ken is offline   Reply With Quote
Old 10-10-2018, 01:46 PM   #12
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Let me throw something out there to consider. We have an Airstream friend that mounted one of the round omni-directional disc antenna's to the top of his antenna mast and claims great reception. He needed to make a new mounting base for it to work but it raises and lowers just like it was designed to do and works well for him. Gonna try it myself one of these days.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 10-10-2018, 01:55 PM   #13
"Omnidirectional" when applied to antennas just means it receives signals equally badly in all directions... (A little Ham radio humor there, but it's true...)
In most cases, an antenna that needs aiming will get a much stronger signal over the "omnidirectional" type, when aimed correctly. With digital television systems nowadays, you either have 'enough' signal to get a picture, or you get nothing. A directional antenna can get a better signal to the set's tuner, and make a difference.
Pulling the Air TV Antenna Replace With A Satellite Antenna Chuhhuniban Electronics & Connectivity 11 04-03-2019 07:11 AM
Antenna Removal & Replacement with Cell/Wifi Antenna BoldAdventure Electronics & Connectivity 10 08-14-2017 07:24 AM
TV Antenna Repair/ replacement/ leaks balrgn Audio, Video & TV 43 04-30-2017 05:05 PM
Rooftop Antenna Installation - Spring Mount Cellular Antenna Astw Electronics & Connectivity 4 08-04-2016 08:51 AM
Replacement Antenna kntd Audio, Video & TV 6 12-05-2002 08:33 PM
