Old 01-04-2007, 10:17 AM   #1
1999 25' Safari
Lafayette ,
Antenna help needed
Just joined and was told all the answeres to my question are located here. I am having trouble with my T V Antenna it will not turn, it raises and lowers but is stuck in one position. This is a recent problem.
theonord is offline   Reply With Quote
Old 01-04-2007, 10:30 AM   #2
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Hi Ted, welcome! I don't know the answer to your question, but I'm sure someone will chime in soon. You might also try the search feature at the top of the screen, in case someone else has already posted this question. Good luck!
Mel
Mel is offline   Reply With Quote
Old 01-04-2007, 10:37 AM   #3
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Hi Ted, Another welcome with no answer to your question.
No worries, someone will have an answer soon - that's one thing that is so great about this site. Nice to have you here!
Dave
Old 01-04-2007, 10:38 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Hello Ted and welcome to the Forums! I haven't encountered this particular problem but let's keep this thread going and see if heavier site traffic in the later afternoon/evening brings any recognition.
First off though -- is it a Winegard batwing antenna?
5 meter Langford Nahanni
Old 01-04-2007, 10:49 AM   #5
ScottW's Avatar
2007 30' Classic
Hernando , Mississippi
I don't want to insult your intelligence, Ted, but I have to ask the question! Are you pulling down on the knob before you try to turn it? (OUCH! That hurt!). If you are and the antennae isn't turning, is the knob turning? Will make a difference on what the problem may be. Let us know. (sorry about the insult...but I had to askº.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 01-04-2007, 10:56 AM   #6
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Welcome Ted
Greetings Ted and welcome to the forums. There are some good questions as noted above which will help forum members perhaps help with your problem. I am assuming (I hate that word) that it did at one time work, is that correct? When you pull down the turn-knob (directional do-hicky thing) does it turn and not the batwing? It could be the inner pin has sheared. In any case, the quick fix to your problem is to have someone sit inside your AS and as you move it sround your campsite they can check the reception and once they have a good picture, park it there! See how great this forum is!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-04-2007, 11:09 AM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
If you post the question in the Forum for Interior Restoration it might get more responses..this area is more for introducing yourself to the group. Welcome to the Forums. Hope you do get a timely answer.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-04-2007, 11:23 AM   #8
1999 25' Safari
Lafayette ,
This knob function worked but ceased to recently, and it does come down but nothing turns
Old 01-04-2007, 11:34 AM   #9
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
Welcome to the forums. I wish I could help you but with each Airstream I have owned one of the first projects was to remove the TV antenna. There is a mess of gears up there, try climbing up on the roof, carefully, pull the cap and check it out. You will find complete diagrams of the gear assembly here, use the search function.
Chaplain Kent
Forest River Forester 2501TS
Chaplain Kent is offline   Reply With Quote
Old 01-04-2007, 11:39 AM   #10
1999 25' Safari
Lafayette ,
Thank you, I'm not particularly computer literate or RV literate and welcome any help including where i can gain the intellect to navigate this site well other than just miles
Old 01-04-2007, 12:55 PM   #11
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Hi Ted,
I you can give us an idea of which antenna you have it would help in narrowing down the repairs. Here is a link to Winegard Odds are pretty good that your antenna is one of theirs. There should be a model number either on the antenna itself or possibly on some paperwork that came with your unit. One of my Airstreams had a sticker inside the pantry door that listed all the installed equipment
Aaron
WBCCI #XXXX AIR #2495
Old 01-04-2007, 03:01 PM   #12
2002 30' Classic
Ocala , Florida
Ted, I had a similar problem on my 2000 Safari. I solved it by raising the antenna and then climbing onto the roof with a can of WD-40. I carefully lubricated the antenna base and then carefully rotated the antenna back and forth while still on the roof. It seemed to be stuck from an accumulation of dirt.
John
Bigdaddy_2 is offline   Reply With Quote
Old 01-10-2007, 04:56 AM   #13
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Ted, I was wondering if you ever got this to work? I have the same probelm with mine.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Jim & Susan is offline   Reply With Quote
Old 02-17-2007, 07:14 AM   #14
1976 31' Sovereign
St Petersburg , Florida
Mine won't go up or turn. I'm going to try to fix it today...in not will replace with DirecTV.
Steve
DreamWeaver is offline   Reply With Quote
Old 02-17-2007, 09:57 AM   #15
Wabbiteer's Avatar
Jupiter , Florida
Gee all I have is a nub and chunk of arm left above the roof on mine - I am curious to put a tracking solar panel back where the antenna was intended to go...
Wabbiteer is offline   Reply With Quote
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Antenna connection PatCrusse Electrical - Systems, Generators, Batteries & Solar 2 10-10-2002 03:15 PM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
