RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 05-03-2017, 01:11 PM   #21
2017 23' Flying Cloud
Lakeport , Michigan
On the interference topic.. today I went looking for the satellite connector in the stereo cabinet (I'm adding a Pathway X2 for Dish) and found the most amateurish rat's nest of wiring, loose audio cables, wads of electrical tape, poor grounding, etc. Just slightly moving the DVD player caused severe radio interference. I moved one power wire and my LED lighting interference on AM radio went away.
Amazing to me to find this on a brand new factory fresh AS.
Fortunately I do have the skills to clean it all up when I have an afternoon free.
Just throwing this out there, as there may well be multiple causes to your AM radio issue.
Hope you solve yours!
Motown is offline   Reply With Quote
Old 05-03-2017, 02:02 PM   #22
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
I've got a similar problem in one of my cars. Drives me nuts because I almost exclusively listen to AM radio. I've been researching the problem, and almost all references suggest that it is a poor ground to the radio. I haven't tried to fix it yet because I have to dismantle half the dash to get to the back of the radio just to check the ground. If you can get to the back of the radio, it might be as simple as attaching a jumper wire to test.
Thalweg is offline   Reply With Quote
Old 05-03-2017, 03:45 PM   #23
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Originally Posted by NoResults View Post
I can't get my 8 track to work either.
Dave
Gold!
pcskier is offline   Reply With Quote
Old 05-03-2017, 08:13 PM   #24
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Originally Posted by franklyfrank View Post
I am completely stumped by the AM radio not working in our 2017 30' Classic.
FM reception is perfect. On the AM channels what we get is mostly loud static very limited voice. This problem exist with the built in Polk radio and any other radio I plug into a receptacle on the trailer.
What I know about radio signals and reception wouldn't fill a thimble. So I need some help understanding and hopefully solving the problem.
It will be a couple of months before we make it to JC for some warranty work.
WHO listens to AM any more? I just use mine to detect thunderstorms in the area.
MelGoddard is offline   Reply With Quote
Old 05-04-2017, 02:20 AM   #25
The Aluminum Tent 3
pcskier's Avatar
Park City , Utah
I will be firing of an email to JC.
Good luck with that!
p.s. I scroll though FM stations endlessly when traveling and hear Rush all the time. Seems most of those shows turn up on FM as well.
Old 05-04-2017, 05:44 AM   #26
2014 22' FB Sport
2017 28' Flying Cloud
Southwest Ranches , Florida
Radio is fast becoming obsolete. If you have reasonable cellphone coverage where you are going you can get almost any station you want.
Mergatroyd is offline   Reply With Quote
Old 05-04-2017, 07:51 AM   #27
Gainesville , Florida
I have a cell phone for emergency use only. It's a nuisance to have one and to be bombarded with the rudeness of those who can't put theirs down,
Old 05-04-2017, 08:11 AM   #28
2016 30' International
Florence , Alabama
Originally Posted by Motown View Post
The LED lighting wipes out AM radio reception on our 2017 FC 23FB. Lights out, AM radio works fine. FM not affected by the LED lights.
DC LED lighting should not affect AM reception; only AC sources.
joshjack is offline   Reply With Quote
Old 05-04-2017, 08:14 AM   #29
Anna Maria , Florida
Originally Posted by KJRitchie View Post
What is the Firefly control panel?
Kelvin
I don't know about other models but the 2017 Classics come without individual switches for the lights and other things. The Firefly is a touch plate switch panel that I believe works wireless and it allows you to turn on the lights and other functions, from different locations. There are three of them on our trailer.
franklyfrank is offline   Reply With Quote
Old 05-04-2017, 08:27 AM   #30
2014 22' FB Sport
Yes it's annoying. The good news is that few people talk on the phone anymore. They text.
Old 05-04-2017, 09:43 AM   #31
Texting is just as annoying as talking, maybe more so.
Old 05-04-2017, 10:46 AM   #32
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
Am
True, its when you have to convert AC to DC that causes the noise. ( That can be minimized as well)
I don't know for sure if the power converter will allow a direct pass through from batteries to LED lights. It should. But like the 'OP' said its that it is the 'firefly control panel' ( That's a pretty fancy control panel ) which could be causing the RF interference.
The ways of RF interference are varied an many.
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 05-04-2017, 12:15 PM   #33
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
AM radio is dependent on antenna efficency. Remember the "old" transistor radios? When you opened it up there was a ferrite bar wound with copper wire. One of the properties of these antenna is that they are directional to a great degree, especially for distant stations. CCrane.com has a couple of solutions that can greatly boost AM performance. The ferrite bar works great, and there is a model called the Term that uses a coil of copper wire and a tunable capacitor to isolate the frequency that you want to listen too. CCRANE is a great company that loves terrestrial radio.
NavyCorpsman is offline   Reply With Quote
Old 05-05-2017, 08:49 AM   #34
Vintage Kin
Fort Worth , Texas
Past the RF interference, I'd look to upgrade the exterior antenna, assuming there is one.
In days of yore it was the 102" whip. Now THAT is an AM antenna.
Closer to today I'd want an extending antenna. FM pretty well calls for 31", and AM is best with longest length (as a rule of thumb).
On our trailers this antenna was nearly always mounted at the street side front corner. A short length from there to the radio.
As with the television antenna, one has a travel position to which to retract.
Old 05-06-2017, 08:15 AM   #35
I had LED lights in our previous 2013 30' International and the AM reception was fine. What puzzles me at no end is that it isn't just the built in Polk radio that gets a serious static interference with the AM reception. I experimented with my stand alone portable radio. I had it plugged into a 110 receptacle on the trailer and I was getting very poor reception wit a whole lot of static. I than turned it on powered by its batteries only, unplugged from the 110 outlet. Same heavy static interference. I also suspected the LED lights and turned them off, no difference. Outside of the trailer no problem the reception is clear as a bell.
Judging by the response received from JC they aren't very concerned about making sure that everything works as it should. IMHO why install a FM/AM radio if half of the radio doesn't work.
In the 2017 Classic the Polk radio is mounted on the wall enclosing the refrigerator. The antenna is mounted way in the back end of the roof.
On the 2013 AS the radio was mounted in the front and the antenna was practically on top of it on the roof.
Basically I was told that they are sorry that the radio doesn't work and to find a different way of listening to AM.
A new 30' Classic is not exactly a bargain basement priced travel trailer.
Daily Notification doesn't work yukionna Forum Admin, News and Member Account Info 26 01-10-2020 02:45 PM
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 02:39 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 05:55 AM
My fridge doesn't work on AC... John Greenlee Refrigerators 3 08-08-2004 11:49 AM
Fridge doesn't work on ac jwaldin Refrigerators 5 04-10-2003 11:38 AM
