Old 07-28-2021, 06:28 PM   #1
2010 25' FB Flying Cloud
Snoqualmie , Washington
2nd TV and factory speakers - need some help??
2010 25' flying cloud. I have two main questions.
1a) Want to have factory front bedroom speakers detached from factory audio, so somebody sleeping does not hear the TV/Radio. 1b) If possible would like them speakers in the bedroom connected to a 2nd TV I installed in bedroom. Not sure how to get to the wires and how this would work.
2) I am wondering if I can mirror the front TV on my new 2nd TV in the bedroom. In the attached pic there is a factory plate with two types of connections, a TV cable type connection (on bottom) and what appears to be something like a cigarette lighter female connection above it. What is that female connection and would that give me the same image as the front TV?
Anders79 is offline   Reply With Quote
Old 07-28-2021, 07:43 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
The best thing to do is on the radio, go to the balance settings, and set the rear speakers to 0. This will stop audio playing in the bedroom. I believe you have a clarion in that unit….
This is not trivial. Those speakers need to be wired to an amplifier to work. The amplifier needs to have input from the TV to work. The wires for those speakers are embedded in the ceiling so Re-routing them is not an option.
You would need to hard wire in a Bluetooth transmitted to the TV, install an amp back near the stereo, connect a Bluetooth receiver to the amp, then pull the speaker wires from the back of the stereo and feed into the amp. It’s messy. You are better off installing a sound bar for better audio in the bedroom.
This is not trivial either, unless you are simply trying to play the dvd on both TVs and you are using a simple yellow RCA cable or are simply trying to watch the same cable TV program using the campground coax / cable connection.
The yellow rca Video cable was standard wiring for airstream before they went to hdmi in 2009 I believe. In my 2008 I could play dvds on either or both TVs.
With hdmi duplicating a signal from a DVD player or Apple TV or what have you to multiple TVs is typically not possible because of digital encryption and copyright.
Others may have other ideas. I’ve redone the AV in both my 2008 and 2017 trailers so have a little experience with how the airstreams are set up.
wulfraat is offline   Reply With Quote
2nd a/c failed for 2nd time Bgibbs Furnaces, Heaters, Fireplaces & Air Conditioning 15 01-02-2019 05:23 PM
Factory speakers Clutch1855 2009-2015 Flying Cloud 7 04-16-2017 12:13 AM
Is this a factory installed solar panel ? I think it's factory installed and ... JacobMerridy Electrical - Systems, Generators, Batteries & Solar 1 01-14-2017 09:23 AM
Floor and Frame fixed, now I need some belly and wrap help heavye Belly Pans & Banana Wraps 3 02-23-2007 12:14 PM
