Old 09-27-2021, 03:37 PM   #1
2020 16' Caravel
Santa Fe , New Mexico
LP Detector on 2020 16RB Caravel
So I have a 2020 16RB Caravel and recently noticed that my LP detector is wired to the main disconnect and does not stay on when disconnected. Also the 1AMP inline fuse is in the main circuit breaker under the bed. Is this normal that the LP only works when the main disconnect is not engaged? Thought the LP was wired direct to a live 12V line and the 1 AMP fuse would be in that wire.
NM Caravel is offline   Reply With Quote
Old 09-27-2021, 04:24 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Does your trailer have a use / store switch *and* a full disconnect switch?
The switch does not enable / disable propane in a trailer. The only way to do that is by turning off the supply with the knob(s) on top of the tank(s). The detector is wired to be enabled when in the "store" setting. The detector is disconnected by the full disconnect (if your trailer came with one).
Old 09-27-2021, 10:14 PM   #3
2019 22' Sport
High River , Alberta
In our 2019 it was wired direct. If the trailer wasn’t plugged in the battery would be dead in a week or two. I added a separate switch.
I’d say that yours is wired properly.
AlbertF is offline   Reply With Quote
Old 09-28-2021, 08:30 AM   #4
2020 16' Caravel
Thanks.
Thanks all. Makes senses I guess. This came about when installing a GPS and track device btw. Was trying to find a live 12V line and thought that the LP detector would suffice. Would highly recommend. Mine was only $119 for device and 2 yr svc., ($20 for 2 yrs after.) and with my solar doesn't drain the battery. Feel that now days its definitely worth it!
caravel
2020 X3 towing a new 16RB prolix21 Tow Vehicles 12 09-25-2021 03:12 PM
2020 Bambi 16RB WD/Sway Control Hitch Questions DJ313 Hitches, Couplers & Balls 2 06-14-2021 11:11 PM
2020 Grand Cherokee Trailhawk V6 for Bambi 16rb? ChristinaS Towing, Tow Vehicles & Hitches 30 09-30-2020 04:04 PM
2020 Bambi 16RB weight question splat matt 2005 and newer - Bambi all models 61 06-20-2020 03:24 PM
