Originally Posted by wmcneil
Lew,
Can one use the CCGX to directly control the Multiplus (without having to use the VRM portal)? (I know you can't configure the Multiplus directly with the CCGX, but the Victron literature seems to imply you can control it with the CCGX instead of the remote control.)
You can control the Multiplus with the CGGX, which lets you turn it to On (Invert+Charge), Charge Only or Off plus setting the current limit just like the Digital Multi Control.
Note that the Digital Multi Control is more convenient since you don't have to go through any menus to turn the inverter on or off.
One way around the loss of convenience is to install the CCGX then buy a cheap 3 way switch to control the inverter (see Multiplus manual), that saves space and money.
