Old 04-07-2023, 07:25 AM   #1
2018 27' Tommy Bahama
Lafayette , Indiana
Where/what model is my converter?
We have a 2018 Flying Cloud FB, 50 amp electric. I'm investigating some battery upgrades. I cannot, for the life of me, figure out where the converter is or what manufacturer/model it may be. The power panel is a wfco model wf-8930/50. The spec sheet for that clearly states it is NOT the converter.
If it matters(don't think it does) its the Tommy Bahama edition.
Any guidance appreciated!
Sjonesin1 is offline   Reply With Quote
Old 04-07-2023, 07:41 AM   #2
Boxite's Avatar
2008 22' Safari
TRue…what you are describing is the “Power Distribution Center”….which is fed power from the actual converter….likely a WFCO 8900. You’ll know the actual converter because it will have a small cooling fan in it similar to a desktop computer.
In my (electricians’) opinion….not every battery change is an “upgrade” (except perhaps in complication and expense.)
If you want more capacity, simply buy/install a larger battery of the same type as the original…OR, install an identical battery in parallel. Simple, durable, and inexpensive.
Old 04-07-2023, 02:42 PM   #3
Lafayette , Indiana
Thanks!
Wat I didn’t detail was that we have 2 std pb interstate batteries that are completely toast and we have some solar plans in the future, so this upgrade was in line with our plans.
I did read reference to the 8900 on the wfco site, but I’d really like to find and ‘touch’ the converter.
Damned if I can locate it!
Magnetek Series 900 Model 950 50 Amp converter / charger Specs & Features? Driver1 Batteries, Univolts, Converters & Inverters 9 12-26-2020 01:35 PM
2017 converter vs. 2018 converter. Mollysdad Batteries, Univolts, Converters & Inverters 14 06-01-2018 07:11 PM
Changing out converter to an inverter/converter combo Aaron-Laura Electrical - Systems, Generators, Batteries & Solar 10 10-09-2017 09:18 AM
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 03:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 03:59 PM
