Old 06-02-2020, 12:28 PM   #1
2017 27' International
Oviedo , Florida
Where is GFI reset?
I have a 2018 27FB Serenity. I can not find the GFI reset receptacle for the trailer. Where is the sucker?
David2638 is offline   Reply With Quote
Old 06-02-2020, 12:43 PM   #2
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
bathroom for me, '13 27 EB
"Chip Tank" is in Redcrest Ca.
CDONA is offline   Reply With Quote
Old 06-02-2020, 01:10 PM   #3
2017 25' International
Kirkland , Washington
Under the bed
In my 2017 Signature 25 FB the converter/breaker box is under the bed. Yours may be in a different location. Once you locate it, open the door to the breakers and there is a GFI breaker on the far right. This feeds the circuits that have receptacles labeled GFI. Mine was tripped somehow and I had the same problem finding where to reset.
ratch is offline   Reply With Quote
Old 06-03-2020, 08:16 AM   #4
Oviedo , Florida
Where is GFI reset?
Thank you for info on GFI location. Not trying to be too obtuse but Is it a typical wall plug gfi or some other configuaration? In 27FB the electrical circuit/fuse panel is To the left and beneath the range top/microwave at floor level? Is the GFI reset in the electrical panel. Thanks
Old 06-03-2020, 08:32 AM   #5
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Where is GFI reset?
David2638- That is unfortunately a very good question. Most homes have the first gfci protected receptacle with the reset button. This gfci receptacle protects others downstream. Why Airstream would use a gfci circuit breaker is strange to me because it is more expensive. This requires a reset at the circuit breaker.
Dan
Old 06-03-2020, 09:25 AM   #6
2018 25' International
Slidell , Louisiana
As others indicated, on newer models, the GFCI is integrated with the breaker and is located in the power distribution center along with the other breakers and fuses. As was mentioned it is more expensive but it simplifies circuit wiring and is slightly less likely to have false trips, and allows use of the shallow outlets everywhere that fit in the thin wall space.
Old 06-03-2020, 05:56 PM   #7
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Ground fault circuit breakers are required by Ohio law that Airstreams must comply with during assembly. The same for copper propane lines. Those use to be black iron depending on the jurisdiction where assemble.
guskmg
Old 06-03-2020, 06:22 PM   #8
west rutland , Vermont
IN our 28ft FC it is to the right of the sink towards the front of the coach. It looks like a regular outlet. Had the same issue and changed every fuse, etc before I figured it out!!
wdaley04 is offline   Reply With Quote
Old 06-03-2020, 06:47 PM   #9
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
Good Question
I have not seen a reset able one in mine either. I havenít needed to yet but Iím sure I will some day.
Thanks!
Mikebrady62 is offline   Reply With Quote
Old 06-04-2020, 09:59 AM   #10
2016 27' International
Aiken , South Carolina
Gfi
Look in the Electrical panel for the GFI Breaker.
dadzpony is offline   Reply With Quote
Old 06-05-2020, 04:31 AM   #11
Rogers , Arkansas
No GFCI breaker listed in my panel.
Old 06-05-2020, 04:51 AM   #12
Long Island , New York
There might be a GFI breaker, Mike, although it may not be listed as such anywhere IMO. A GFI breaker looks different that the others, and has a fairly obvious reset button on it [red? yellow?], in addition to the main breaker throw switch. [Edit -- You said you did not see one "listed," so please look at the actual circuit breakers again, per the photo below.]
If you don't have a GFI breaker, then at least one of your 120-volt duplex outlets should be a GFI outlet, which protects other outlets in the same circuit. Usually in the galley or head IMO.
The electrical diagram in your owner's manual should indicate these possible locations, at least in a generic schematic view IMO.
PS -- As Dan said earlier:
Originally Posted by TouringDan View Post
. . . Most homes have the first gfci protected receptacle with the reset button. This gfci receptacle protects others downstream.
Good luck.
Let the music lift you up . . .
Have a little pun in life . . .
Peter
Old 06-05-2020, 06:48 AM   #13
Slidell , Louisiana
Indeed, on page 8-29 of your international manual you will find that either 30A or 50A service the GFCI breaker will be on the far left in the power distribution center as Peter has indicated.
Old 06-06-2020, 10:19 AM   #14
Rogers , Arkansas
Found It!
Plain as day when you know what to look for
Thanks to OTRA15 & Brian Bayou Biker!
Here is mine on 2019 27' FBT; white reset button instead of yellow or red. DUH
50 Amp panel.
Name:	AS Electric Panel.jpg
Old 06-06-2020, 10:53 AM   #15
aftermath's Avatar
Spokane , Washington
Mine went out last year and wouldn't reset. I had to replace the breaker as it had gone bad. Very easy job......but.......expensive.
aftermath is offline   Reply With Quote
Old 06-06-2020, 11:02 AM   #16
Thanks for the update Mike . . . happy trails!
Peter
Old 02-25-2021, 08:14 AM   #17
2018 28' Tommy Bahama
san pedro , CA
On the road in a 2018 tommy B. GFI breaker won’t reset, are these readily available? Thanks
Airdog9 is offline   Reply With Quote
Old 02-25-2021, 08:37 AM   #18
ITSNO60's Avatar
Tucson , AZ
Hopefully you forced it hard to "OFF" first otherwise it will not reset. Doubtful that the breaker is bad. Unplug all loads first.
Brian
ITSNO60 is offline   Reply With Quote
how do you reset the inverter dsrtgrls Batteries, Univolts, Converters & Inverters 2 02-19-2021 04:30 PM
Can't reset circuit breaker evamcmahan Electrical - Systems, Generators, Batteries & Solar 2 03-21-2010 08:54 AM
Thermal Breaker Reset n2916s Electrical - Systems, Generators, Batteries & Solar 6 10-11-2009 04:00 PM
Do you reset the brake controller for wet weather? richinny Brakes & Brake Controllers 4 06-12-2009 04:49 PM
Electrical Newbie with circuit breaker that won't reset...help please! Kerina Electrical - Systems, Generators, Batteries & Solar 13 05-04-2008 09:18 AM
