Old 01-06-2018, 03:58 PM   #21
Toaster Life
2010 23' International
Tucson , Arizona
I hope I am not camping next to you and listening to your generator all night.....
Toasterlife is offline   Reply With Quote
Old 01-07-2018, 06:45 AM   #22
chugchug's Avatar
2018 25' International
Belmont , California
You connect the trailer's negative to the - terminals of 2 and 4. Positive its the + terminals of 1 and 3.
chugchug is offline   Reply With Quote
Old 01-07-2018, 07:02 AM   #23
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
One cannot carry enough batteries to make an RV furnace a reliable source of heat in below freezing temps.
That is why 70/80s vintage trailers came stock with catalytic heat sources.
This comment will no doubt start the usual pot shots about furnace ducting to the tanks, how dangerous catalytic heater are, and others.
We use a portable catalytic heater in cold boondocking situations.
The furnace ducting does not furnish any more heat to the tank area that having a constant 70 degree cabin temp above them.
As much as everyone complains about the size of the holes drilled in the floor by the factory for plumbing/ducts/wiring, as well as the seal of the cabin door, I think we can all agree an Airstream trailer is about as air tight as a screen door. Crack a fan vent if one is worried about CO.
Just an option, no battery worries, no fuss.
Regards,
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 01-07-2018, 12:18 PM   #24
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
Originally Posted by chugchug View Post
you connect the trailer's negative to the - terminals of 2 and 4. Positive its the + terminals of 1 and 3.
KK4YZ is offline   Reply With Quote
Old 01-07-2018, 07:24 PM   #25
2007 23' Safari SE
Annandale , New Jersey
Thanks. Would that mean then that the connections drawn (-2/-4) (+1+3) would be redundant and not needed?
Fred L is offline   Reply With Quote
Old 01-07-2018, 08:06 PM   #26
chugchug's Avatar
They are still needed.
Old 01-08-2018, 02:58 AM   #27
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
these 6 volt battery posts remind me of the big truck manufacturers in the 1960ís to about 1980...you had to have 4 6 volt batteries or your diesel engine wouldnít start...everyone had 24 volt starters, and everyone had lots of battery problems, and they still didnít start that good....then by the middle 1980ís it all went back to 12 volt, 2 batteries, some of the freight companies run only 1 12 volt battery....and most battery problems went away...then my KW has 3 12 batteries.....usually get 6-7 years out of interstates, they are greased when new ...with our as , I carry a 2000 Honda..that keeps it real simple and economical..
Dual Battery Setup with Automatic Charge Relays Snowy Batteries, Univolts, Converters & Inverters 14 05-02-2017 02:48 PM
Need help with Dual Battery Setup cityslicker Batteries, Univolts, Converters & Inverters 16 01-19-2017 04:02 PM
My Battery and Distribution Setup and Choices. crabbey1 Electrical - Systems, Generators, Batteries & Solar 19 09-28-2014 12:57 PM
Battery, Solenoid, Isolator Setup kennytheecat Electrical - Systems, Generators, Batteries & Solar 4 04-23-2009 08:45 PM
Figuring out what is going on with my trailers electric setup... Andy R Electrical - Systems, Generators, Batteries & Solar 1 03-30-2002 10:59 PM
