Old 12-16-2020, 09:08 PM   #1
2021 23' International
P , California
Vitron 1000 change settings?
Is it possible to change the settings on the Vitron 1000 inverter/charger that comes stock in a new Airstream? That is, if installing two drop-in Lithium Ion batteries can the stock Vitron charge voltage rate be raised from 13.6 to 14.6?
The adventure begins when things stop going as planned.
https://youtu.be/Y3Gqm6__860
viking1 is offline   Reply With Quote
Old 12-17-2020, 10:10 PM   #2
2018 30' Flying Cloud
sebastian , Florida
Ditto
I have a 2018 fc and want to drop in two lithium batteries to replace lead acid batteries from factory install. What changes need to be made to the system to allow this to work properly.
Samrh is offline   Reply With Quote
Old 12-17-2020, 10:24 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
It sounds like you have a Victron MultiPlus 1200 / rated at 1000w output continuous.
Yes, you can set the multi voltage for lithium. The easiest way is to use the dip switches per section 5.1 of the manual (link below). You can also use the VEConfigure tool to manipulate the Multi configuration.
https://www.victronenergy.com/upload...R-DE-ES-IT.pdf
wulfraat is offline   Reply With Quote
Old 12-17-2020, 10:25 PM   #4
wulfraat's Avatar
You need a new lithium-specific converter/charger if you want to treat your lithiums right.
Old 12-18-2020, 05:32 AM   #5
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
If I may offer some advice, check the battery box size and the size of the batteries carefully. I tried to install two Battle Born lion in the box on my 2018 GT and two will not fit.
Of course there are other battery suppliers and they may have batteries that will fit but don't assume like I did.
Hans627 is online now   Reply With Quote
Old 12-18-2020, 07:18 AM   #6
P , California
Thanks amigo. Can you tell me where the Vitron inverter/charger is located in the the 23FB is? Is it easy to access for adjusting?
Old 12-18-2020, 07:23 AM   #7
wulfraat's Avatar
Sorry don't know. Likely behind the power center or under a dinette bench if I have to guess.
Old 12-18-2020, 07:33 AM   #8
2019 27' International
Western NC , North Carolina
I have a 2019 International and two of these fit in the factory box, they also offer this battery with a built in heater for cold temps.
https://battlebornbatteries.com/prod...cycle-battery/
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 12-18-2020, 08:19 AM   #9
sebastian , Florida
Great news. Thank you. I will check my controller this am and see if I can use it. I would like to extend my Amp Hours beyond the 90 I got with my rig.
Old 01-13-2021, 11:20 AM   #10
P , California
Fyi
Turns out that I was misinformed by the dealer (shocked absolutely shocked) in that the 2021 23FB does not come with a Victron charger. It is actually a WFCO Model # WF-8955PEC-J and cannot be altered but rather needs to be replaced with this model for charging Lithiums which require 14.6 volts. My apologies if I have confused anyone by my original post.
Old 01-13-2021, 09:13 PM   #11
wulfraat's Avatar
I’m not shocked that the dealer is clueless. I was surprised that the claim was airstream put a sophisticate Victron multiplus inverter/charger as standard equipment vs a $100 DC converter.
I’m a Victron fan. That being said I’d recommend you replace the WFCO converter with a progressive dynamics unit calibrated for lithium. Plug and play.
For your system keep it simple and replace the converter. $215 bucks or so plus labor. Done. Lithium’s are charged correctly and you can use your factory inverter to watch TV or what have you when off grid.
Bestconverter.com is your friend.
Specifically:
http://www.bestconverter.com/PD9145A...l#.X__FRaRHbDs
Old 01-14-2021, 06:52 AM   #12
P , California
Specifically:
Thanks. This is the model that WFCO recommended. My trailer system is 30Amp not 50 amp. I noticed that you are recommending a 45amp converter. Which works best?
https://ltdrvparts.com/PROGRESSIVE-DYNAMICS-55-AMP-LITHIUM-CONVERTER-SECTION-PD4655LIV-PD4655LIV.htm
Old 01-14-2021, 12:02 PM   #13
wulfraat's Avatar
PD4655 lithium profile is perfect
Old 01-14-2021, 05:14 PM   #14
P , California
Thanks again. Two more questions:
I am installing a Zamp 170 watt roof panel that I won't be expanding ever and need to know what size Victron solar charger to install. (Bluetooth model)
And I read somewhere but forgot, where the pre-wire connections are located for mounting the controller inside the trailer. Is it in the bathroom near other monitors there or in the kitchen wall?
Old 01-14-2021, 08:01 PM   #15
wulfraat's Avatar
Victron 75/15 smart controller is what you want then.
170/13 = ~13amps DC to the batts.
There is a roof mounted 3 port connector for the panel.
Not sure where the inside termination is on the 23 - it’s at the DC bus bar likely but not sure where that is in your trailer - likely under a bench.
Old 01-23-2021, 08:22 AM   #16
P , California
Thanks again. I found the +yellow and -green factory-installed solar panel wires that come out directly next the the 12 volt bus bar and inverter. I can see where to connect the two solar wires to the Victron charge controller but am unsure of where to connect the +&- wires coming out from the controller. Where on the bus bar should the + connect? And then where to connect the - wire? Somewhere on the negative bus bar?
ID:	387382   Click image for larger version
Vitron charge controller swap out mazoolah Generators & Solar Power 5 08-16-2020 09:30 AM
how to change settings? huck55 Forum Admin, News and Member Account Info 1 10-01-2019 01:39 PM
Mid twenties furnace settings ? Robbie R. Winter Living 12 12-16-2009 04:38 AM
Equalizer Installation Settings temcotom Hitches, Couplers & Balls 5 06-13-2004 10:56 AM
Electric Cooling Fan Settings rdm Mechanics Corner - Engines, Transmission & More... 1 07-12-2002 06:29 AM
