Old 03-19-2021, 05:41 PM   #1
2019 27' International
Western NC , North Carolina
Victron Smartshunt
I did the factory lithium upgrade to my 2019 with solar. System works as advertised but I realized there was really no way to monitor state of charge.
So I had a Victron Smartshunt installed which is a battery monitor without a display. It connects via Bluetooth to an app on your phone and gives you all the data.
Wicked cool install as we did not have to add a display somewhere.
2019 International Serenity 27 FBQ “TC Escape”
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 03-19-2021, 06:27 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Yes they are awesome! Highly accurate too!
Make sure you calibrate it by fully charging your batteries, then in the settings in the app you can set as 100% state of charge. you will also want to ensure other settings on the BMV are correct per lithium specs (Charged Voltage, Peukert Exponent, Tail Current, etc..).
Here is a hand page with links to BMV settings for different lithium batteries...
https://amsolar.com/victron/monitor-vtbmv-s
Always good to double check that your settings are correct to ensure maximum accuracy.
wulfraat is offline   Reply With Quote
Old 03-19-2021, 07:56 PM   #3
Thanks, did all that as part of setup process, easier when you’re plugged in and have solar so I knew we were at 100% when we started the install.
Old 05-31-2021, 06:51 PM   #4
2017 30' Flying Cloud
East Blue Hill , Maine
Update on Smartshunt?
Are you happy with this install? Any concerns? Considering the same monitor and was interested in your thoughts.
Air4ME is offline   Reply With Quote
Old 06-05-2021, 02:16 PM   #5
ITSNO60's Avatar
Tucson , AZ
I'd like to know also how you are liking the Smart Shunt. I was all set to order one when I read a lot of negative reviews, of course some are probably user error.
Brian
ITSNO60 is offline   Reply With Quote
Old 06-05-2021, 02:46 PM   #6
Works fine no issues.
Old 06-19-2021, 01:30 AM   #7
AShar's Avatar
2019 25' Flying Cloud
Walnut Creek , California
I installed the SmartShunt in the battery box and I am very happy with it. Yes, it's true that the BT range is limited in the metal enclosure, but it's good enough for typical needs. Seems to work fine from the bed area in our 25FB, this is where I tend to need it the most to check on SOC during cold nights.
I have not yet installed the Lithium batteries though, it's running with my AGMs and I am not getting an accurate SOC. Does anyone has experience using a shunt with AGMs? It was showing 99% SOC when the voltage was just 12.2V, which if I go by my old chart means 60% SOC. Has anyone else experienced it. It appears that I am losing charge due to self-discharge of batteries.
2019 25FB Flying Cloud
2021 Range Rover HSE
2019 RAM 2500 Hemi
2012 Mercedes GL450
AShar is offline   Reply With Quote
BMV comparison: Victron 712, Victron 700-02, v. Ali Battery Monitor JeffofCT Electrical - Systems, Generators, Batteries & Solar 9 09-16-2020 07:22 PM
Victron 100/30 vs Victron 100/20? smsasf Generators & Solar Power 0 08-04-2020 06:09 PM
Victron 100/30 and Victron 712 installer needed in PA RMD Generators & Solar Power 0 07-01-2020 09:08 AM
Victron Battery Monitor with Bluetooth connection to smart phone jhart657 Electrical - Systems, Generators, Batteries & Solar 23 07-27-2016 01:56 PM
Victron Multiplus Hybrid/Boosting Inverter/Charger Install CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 7 03-15-2016 11:03 PM
