Old 05-12-2024, 02:57 PM   #1
TetonStreamer
Teton Stream's Avatar
2021 27' Flying Cloud
Delaplane , Virginia
Victron MPPT 150 I35
I have a 2021 27FC with factory solar. It has a Victron MPPT 150 35 Bluesolar Controller installed. I started to install the Victron VE Direct Bluetooth Smart Dongle and found a cable already occupying the plug where the dongle inserts into the MPPT controller. It is factory labeled Solar CTL. What is its purpose? Can it be removed for the Smart Dongle?
I did plug in the MPPT Controller and updated firmware and have reconnected the Solar CTL cable.
Teton Stream is offline   Reply With Quote
Old 05-12-2024, 03:10 PM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
Do you already have a Victron display somewhere that's indicating what the solar controller is doing? Another thread states that the display plugs in the same place as the BT dongle does. Info about the Victron BMV-700 monitor suggests that the BT dongle can plug into the monitor as well, though I don't know if you'd get the same info as from the charge controller directly.
David
Zero Gravitas 2017 Flying Cloud 26U | WBCCI# 15566
Victron MPPT 150/35 Panel limit turonueve Batteries, Univolts, Converters & Inverters 11 11-20-2022 12:57 PM
Add Victron Bluetooth Dongle to MPPT 150/35 retired-ccie 2018 - Current Globetrotter 27 07-12-2022 08:08 AM
Victron MPPT 150/35 jfreeham Generators & Solar Power 1 09-19-2021 06:57 AM
2021 Factory Victron BlueSolar MPPT 150/35 TrailDude Generators & Solar Power 31 05-17-2021 10:11 AM
Victron BlueSolar MPPT 150/35 Solar Controller w/BlueTooth Dongle ghaynes755 Airstream Classifieds 0 01-18-2020 04:00 PM
