Old 10-18-2021, 05:45 PM   #1
2021 27' Globetrotter
2015 25' FB International
Victron BlueSolar Solar Controller Location in 2021 Globetrotter 27FB
Our 2021 Globetrotter 27FB came with a Victron BlueSolar 150/35 MPPT Solar Charge Controller for the factory solar panels. Unfortunately the BlueSolar doesn't have bluetooth built in to use the Victron Connect app, so I need to add the bluetooth dongle. Does anyone know where the solar charge controller is located?
Thanks.
BBardua is offline   Reply With Quote
Old 10-18-2021, 08:00 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
It should be under the front curb side of the bed. Close to the DC distribution box.
Old 10-19-2021, 03:22 PM   #3
Thanks. That's what I assumed but obviously didn't look closely enough the first time. I see it now tucked in behind the DC panel.
B
Old 10-19-2021, 03:40 PM   #4
ts8501's Avatar
2022 25' International
Savage , Minnesota
I am interested in your install of the dongle, and whether you see value in the addition. I just tried to connect the app today to it, and realized the Bluetooth option is missing (2022 International)
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 10-19-2021, 04:32 PM   #5
dznf0g's Avatar
Oswego , Illinois
I installed a Blue Solar several years ago and then got the dongle. I use it A LOT!
-Rich-
Old 10-19-2021, 11:51 PM   #6
From all the research I've done, you get a lot more control and info than you do when using the installed control panel. For example, I've just replaced the AGM batteries that came with the unit with two 100AH lithium batteries. Reprogramming the solar controller through the control panel is cumbersome and doesn't give you the ability to disable equalization (although you can just set it to the same voltage as for absorption and bulk) or disable temperature compensation (which lithium doesn't require because of the the built-in BMS). The app can also be used with Victron battery monitor so there's value to having both on the app.
Old 10-20-2021, 10:38 AM   #7
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Bluetooth is pretty much a "must have" item on the Victron gear. No matter what the device, you get a *lot* more capability with it hooked up. The only real alternative is to buy one of their central controllers and access this or that feature through it.
Old 11-13-2021, 02:00 PM   #8
ts8501's Avatar
Savage , Minnesota
I have installed the Bluetooth dongle now, and I do like the app. I didn’t realize I had to give up the round MPPT wall display in order to add the Bluetooth Dongle. They both need the one ve.direct port on the 150/35. Or am I missing something?
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 11-14-2021, 08:30 AM   #9
Half a Rivet Short
2022 Interstate 24X
Hi
Welcome to why you go with the "Smart" MPPT ....
Old 11-14-2021, 08:44 AM   #10
dznf0g's Avatar
Oswego , Illinois
Hi
Well, for me....the Smartsolar models weren't out when I bought.
For AS...well....they are cheaper.
-Rich-
Old 11-21-2021, 09:26 AM   #11
ts8501's Avatar
Savage , Minnesota
I tried to get an answer to this question on a different thread, but let me try here.
With factory solar and a Victron Solar controller, when you use the Zamp Port for additional portable panels, do the portable panels also need their own solar controller? I think the answer is yes, but “think” is not good a good strategy ;-)
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 11-21-2021, 10:05 AM   #12
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I installed 2 90 watt zamp panels with a victron controller…I am going to tie in a external plug for an additional panel …
Old 11-21-2021, 10:16 AM   #13
OrangeCrush's Avatar
2017 25' Flying Cloud
Longmont , Colorado
The answer is absolutely yes, panels plugged into the Zamp port need their own charge controller. The Zamp port is simply a direct connection to the batteries.
OrangeCrush is offline   Reply With Quote
Old 11-21-2021, 10:47 AM   #14
ts8501's Avatar
Savage , Minnesota
Perfect; thank you!
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 11-22-2021, 12:21 AM   #15
I concur with OrangeCrush. We have 180W on the roof and also run a 230W Zamp suitcase through the external Zamp port. The solar controller in the unit only controls the roof mounted panels.
Old 11-22-2021, 08:48 AM   #16
Lawrenceville , New Jersey
Is it possible to rewire the external Zamp port to connect to the built-in solar controller?
jeffb831 is offline   Reply With Quote
Old 11-22-2021, 12:43 PM   #17
Longmont , Colorado
Just to be clear, I am referring to the Zamp port on the front of the trailer for a portable panel, NOT the extra ports on the roof.
To answer your question, yes it is possible, but I would advise against it for at-least 2 reasons. 1) You may exceed the power rating of the on board controller, and 2) Unless you get the exact same panels the mis-match will negatively effect your MPPT controller's ability to find the maximum power point. Both will result in less than optimal power and possibly damage to the on board controller. Most portable solar kits include a charge controller so best to stick with one of those or buy a controller to add to what ever panel you are trying to plug into the portable panel port.
Victron BlueSolar display scrolls CONNECTING kmrice Generators & Solar Power 9 08-03-2021 11:08 AM
2021 Factory Victron BlueSolar MPPT 150/35 TrailDude Generators & Solar Power 31 05-17-2021 11:11 AM
Victron BlueSolar MPPT 150/35 Solar Controller w/BlueTooth Dongle ghaynes755 Airstream Classifieds 0 01-18-2020 05:00 PM
BlueSolar vs. SmartSolar jkingseed Generators & Solar Power 7 06-24-2019 04:02 PM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 07:13 PM
