Old 09-25-2020, 09:55 AM   #1
1976 31' Sovereign
Round Rock , Texas
Univolt replacement...No 12V shore power
Hi.
I need a new power supply and distribution panel for my 76 Sovereign.
Just 4 wires it looks like to 4 circuits that are 12VDC.
Here is a picture of what I think should be behind the stove accessible via access panel by entrance door. What I have now is a mess and a huge power supply from the 70s. Original Univolt panel is gone.
Here is picture of what I would like to have back in my rig.
Anyone know where I can build/find such a distribution panel?
Paul
Name:	2nd Univolt for my 1976 AS.jpg
Paul Palmer
1967 VW Camper Van
1976 31' Sovereign RB Twin Airstream.
pjpalm1964 is offline   Reply With Quote
Old 09-25-2020, 10:55 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
You didn't ask, and I am being cheeky to stick my oar in, but... replace the old univolt with a third generation converter. Univolts fry batteries. This is one area where newer tech really is better. A 76 Sovereign is not a rare historically significant design worthy of historical restoration. If you want to keep the vibe do so, but behind the scenes upgrade some of the technology. Converters aren't that expensive.
Old 09-25-2020, 12:47 PM   #3
1966 22' Safari
Fredericksburg , Texas
Check out Progressive Dynamics. Weíve replaced two Univolts with 3-stage converters from this company. Good luck
Bubba L is offline   Reply With Quote
Old 09-25-2020, 02:45 PM   #4
1976 Argosy 28
Buford , Georgia
+1 on the progressive dynamics, Also I got a 6 slot fuse block and added it to separate out the circuits, Blue Sea is a good one to get, also some of them have the added benefit when a fuse blows an indicator light will show which fuse it is.
For my 76 Argosy I replaced the 30A Univolt with a 45amp PD supply, went LED's all around so that helps a lot with the load on the system.
One example of fuse box:
https://www.campingworld.com/st-blad...B&gclsrc=aw.ds
John
strangepod is offline   Reply With Quote
Old 09-25-2020, 05:29 PM   #5
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I replaced the Univolt on my 1976 with a Progressive Dynamics PD9245 and used the original ditribution panel. Easy change over, and saved my battery!!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 09-25-2020, 06:52 PM   #6
1976 31' Excella 500
Crewe , Virginia
I found a WFCO 9855 for our 76 Excella. I went a little different route with than most people would......attached link. Only swapped out the old Univolt and kept the fuse panel. Everyone has a different choice, so youíll have plenty to choose from......
Dspchef is offline   Reply With Quote
Old 09-26-2020, 09:49 AM   #7
Ctmchristo's Avatar
1973 29' Ambassador
Sacramento , California
Univolt Replacement
Based on this thread I will definitely replace mine. My question is does it have to go in the same place as the univolt? Is there a way to move all power related stuff to the back without taking everything out? We arenít removing much and using existing cabinets and countertops.
Ctmchristo is offline   Reply With Quote
Old 09-26-2020, 12:12 PM   #8
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
You can locate it anywhere , but the wires( circuits) need to be extended or back fed from the new location
bibbs is offline   Reply With Quote
12v
Dometic refrigerator wonít run on shore power& water heater light on when on shore po fotoman1527 General Repair Forum 22 04-10-2018 02:57 PM
12V Power Plug in for 12v T.V. Undertaker Electronics & Connectivity 12 09-10-2016 08:53 AM
no shore power through Univolt Horsley1 Electrical - Systems, Generators, Batteries & Solar 4 01-10-2013 01:38 PM
Univolt/ battery/ shore power question Lumatic Batteries, Univolts, Converters & Inverters 6 05-21-2007 08:10 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
