Originally Posted by lewster
If you use 'Z feet' as mounting brackets for your solar panels and screw then into your roof, you will really have a difficult time removing them for cleaning/inspection.
AM Solar's rocker foot mounting system allows you to easily tilt the panels for complete access under them for inspection/cleaning. They are also adjustable and allow you to mount the panels level to the ground so that they all receive the same amount of solar radiance regardless of the sun angle. Definitely a better way to go!!
Thanks for the information.
