Old 03-08-2014, 02:30 PM   #1
Coaster's Avatar
2020 16' Nest
Saint Augustine , Florida
Tripping ground fault on shore power.A few days ago it was pouring rain so I went to
Keep tripping in the garage. The breaker that says bedroom
Converter would trip the ground fault in the garage.The ground fault doesn't trip anymore but I smelled something like a slight burn of wires.
When plugged in the solar regulator would read 13.7-9. Now it seems that there's no change when plugged in .
Have a trip planned in 2 weeks, need advice. Problem or not.
Coaster is offline   Reply With Quote
Old 03-08-2014, 02:58 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Your outside 120VAC outlet is a common cause for tripping GFCI, it gets moisture in it and causes the problem. You can dry it out with a hair dryer just don't go overboard with the heat.
You may have also tripped your Airstream bathroom GFCI.
Garry
garry is offline   Reply With Quote
Old 03-08-2014, 05:35 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
As a rule, it's best not to plug your Airstream's shore power into a GFCI outlet in your garage. When one GFCI circuit is plugged into another GFCI circuit, the "upstream" GFCI sometimes mistakes the downstream GFCI as a fault.
If all of your garage outlets are GFCI, you might want to shut off the GFCI breaker in the Airstream for the duration, just to be sure; the garage GFCI will provide all the protection you need.
Old 03-09-2014, 12:11 PM   #4
Coaster's Avatar
2020 16' Nest
Is there an easy way to the
Converter? When I turn on the over head lights the solar regulator drops some. Not only did trip the ground
Fault but also the GFI breaker in the panel box.One new outlet was installed during the conversion when checked it read hot/neutral reverse.
Old 03-11-2014, 03:55 AM   #5
Coaster's Avatar
2020 16' Nest
Thanks for the advice. But I have another parallax7300
Casualty. Fried ceramic capacitor. Time to up grade to 3 stage converter.
Shore power requirments for trailers Mrcrowley Generators & Solar Power 21 08-02-2017 05:20 AM
Rain Leak 2004 Bambi CowtwnSilver Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 10-21-2011 05:26 PM
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 10:47 AM
Roof Leak during heavy rain andyfuson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 12 03-21-2011 12:33 PM
