Old 01-29-2018, 08:44 AM   #1
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
to maintain batteries while stored
Going to leave trailer on lot for 8 months. Will be connected to power and a dehumidifier running.
I have the original converter. My plan is to turn the battery switch to store and then connect a automatic trickle charger to the batteries to maintain charge.
Will this plan work okay? Will one trickle charger maintain both batteries?
thanks for any suggestions
Old 02-01-2018, 05:42 PM   #2
2015 30' Classic
Pleasanton , California
Should be fine.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 02-01-2018, 06:59 PM   #3
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
How many amps does the humidifier draw? You will need to have a charger that supplies an amp or two more.
Mattirs is offline   Reply With Quote
Old 03-26-2018, 12:50 PM   #4
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
the humidifier will pull power from the 120 system not the 12 v i would guess to be true. the charger will not come into play. If you have a stock or OEM charger you might want to put it on a timer to come on for 30 mins every day and off the rest of the time. helps to keep the batteries from losing water over that time frame.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 03-26-2018, 01:07 PM   #5
Mollysdad's Avatar
I'd consider disconnecting the batteries, (by removing the black cables going inside), put the converter in "store" and a trickle charger across both batteries, one positive and the other battery's negative. Since the batteries are in parallel, they make a big 12 v. battery.
In theory the converter won't be supplying juice, but I'd probably tape over the loose cables anyway.
Old 05-19-2018, 10:59 AM   #6
1988 25' Excella
1987 32' Excella
Took the batteries out and put them in the shed. Bought 2 trickle chargers and put on on each battery.
But the golf cart batteries are just sitting there in the cart.
Old 05-19-2018, 01:07 PM   #7
rperrym's Avatar
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village , Arkansas
I assume the dehumidifier will be connected to a drain to the outside or the gray water tank?
2017 27 Tommy Bahama
2020 2500 GMC Duramax
rperrym is offline   Reply With Quote
Old 05-19-2018, 01:36 PM   #8
1988 25' Excella
1987 32' Excella
Drain line is rigid piped to the sewer. Gray water valve is open. De-Humidifer is sitting on kitchen counter with hose draining into sink. Worked last 2 years this way.
Old 05-19-2018, 02:33 PM   #9
rperrym's Avatar
Great way to do it. Thanks for the good idea.
Old 05-19-2018, 02:46 PM   #10
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Hitting the batteries forever and ever with a trickle charger is not going to kill them, but it also is not the greatest thing for them. A dirt cheap mechanical timer that fires up the charger(s) once a week for a couple hours would help things more than just a little. That of course *assumes* the particular chargers you have don't get stupid when the main power goes off. A quick check with a multimeter will show you if they pull current when unplugged from the wall, but still on the battery. Anything under 10 ma is a "don't care about it" sort of number in this case.
Old 05-19-2018, 03:58 PM   #11
1988 25' Excella
1987 32' Excella
Thanks Bob. Did not know that. Probably should have. The batteries will have to survive on their own until I get back to them in Jan. Usually I just unhook the grounds and let them sit. Thought I would be ahead with the trickle chargers since that is what they are advertised to do. I buy lots of batteries. That trailer is going to the the converter upgrade when I get there. But what I think you are saying is that the newer converters still harm the battery when sitting?
Lets see: 4 batteries in the trailers, 2 in the boat, 6 in the golf cart, 2 in my truck, and 1 in the Subaru. Plus I wear hearing aids and change twice a week. And not to forget the half dozen or so Lithium tool batteries. I spend a lot of my income on batteries. And I bet a lot of people have more batteries than I do. I do not seem to be able to maintain them well. Most of them sit somewhere most of the time. And when I use them I draw them down too far.
Old 05-20-2018, 07:00 AM   #12
Half a Rivet Short
Hi
All most of these gizmos do normally is put a constant voltage on a battery in storage. A few of them go into some rock and roll once a month or so. My only point is that there is no need / value in putting a constant voltage on 24 hours a day 7 days a week. Some of the same rock and roll can be accomplished by hitting them once a week. Is it a really big deal?
nope. Might it extend a battery by a season? maybe .... timers are cheap.
The bottom line is still that lead acid batteries last a lot less time than most people think they do. Use them in high discharge / deep discharge applications *and* combine that with a lot of "do noting" storage ..... not so great. Your car or truck battery lasts as long as it does because it does not get a deep discharge ever and it's cycled daily ( or at least weekly).
Some math:
Starter motor on the car pulls 180A. It turns over for 10 seconds. Start the car 6 times a day = 60 seconds = 1/60 hour. You have pulled 180/60 = 3 AH out of the battery all day.
Your 40AH car battery gets hit less than 10% that day.
If you have a parasitic load of 1A on your trailer ( you might not ...) your 200 AH AGM bank on the trailer dumps 24 AH per day. That's sitting doing absolutely nothing at all. Your trailer sees > 10% drain on a day in storage.
Battery Charging while Stored GLovedahl Batteries, Univolts, Converters & Inverters 18 10-16-2020 03:13 PM
How to properly maintain hickory cabinets m.hony Upholstery, Blinds, Walls & Interior Finishes 6 12-27-2013 05:12 PM
Clearcoat to Maintain Appearance?? Help! big_john Clearcoat, Exterior Paint & Trim 0 05-30-2011 10:53 AM
Is AS MH difficult/expensive to maintain/repair? aaastircrazy Mechanics Corner - Engines, Transmission & More... 6 09-04-2009 08:09 AM
How should I clean & maintain the exterior AccessMaster Cleaning, Stripping & Polishing 11 11-14-2005 06:20 PM
