12-05-2024, 01:34 PM
#21
19’ Bambi Flying Cloud
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia
, Husqvarnia
Appreciate the update. Good to know about the warranty being voided by shaving the handles. That seems unreasonable to me, but nevertheless good to know. I guess I would make a slight mod to the battery box, then, to accommodate the handles.
2017 Bambi 19 Flying Cloud
12-05-2024, 02:39 PM
#22
Journeyman
2016 25' International
Amherst
, Massachusetts
Try Renogy Core Mini
Hey there... I have a 2016 trailer as well so our battery boxes are probably the same size.
You might take a look at Renogy's new "core mini" 100ah battery. I was able to easily fit three of them in my battery box. Plenty of height and space enough for a (yet to be installed) blue sea cutoff switch.
12-05-2024, 04:20 PM
#23
2023 25' Globetrotter
2021 16' Bambi
Forest Lake
My, they have gotten a lot smaller.
Just wondering, it appears to me the batteries are not in balance. The battery with the postive cable coming in should be the last battery with a negative cable. And vice-versa the negative coming in should be the last in line for the postive cable.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
12-05-2024, 04:31 PM
#24
2015 Interstate Grand Tour
Salem
, New Hampshire
Originally Posted by JeffKim
Looks great! I was wondering too about fusing. It looks like you retained the MRBF fuses? I kept ours for the inverter and batteries when I installed our 400Ah, but a lot of people use a Class-T.
Also, keeping the Victron shunt means you can use the VE.Smart Networking if you have a Victron Smart solar charger or add other Victron equipment in the future.
I’ve gone down the redundancy route and have added both. Each positive terminal has an MRBF fuse and I have a Class-T about 8” off the positive battery terminal.
Originally Posted by Bnystrom
While Class T fuses may be the best type for the application, they're expensive, can be hard to find, and most important for this installation, they're bulky. I don't see where he could actually fit one, or even an ANL fuse and holder.
This use to be case during COVID but now readily available. Victron now also makes a Lynx Class-T Power In that allows you to put two class-t fuses in them. However, for the OP it might be tough to add it as you want to have a class-t fuse as close as possible to the battery.
Lastly, the Epoch 460 Ah batteries come with a built in class-t fuse which is nice. A bit too big to fit for the OP though. It’s probably just a matter of time before Epoch probably starts installing them inside the 300 Ah batteries which will be nice and welcomed.
Now I have triple redundancy as our 460 Ah Epoch batteries have built in class-t fuses. Now we have an MRBF fuse on each positive battery terminal, a class-t fuse 8” from the closest battery positive terminal and one each class-t fuse in each battery. Hey - I can sleep better at night!
Victron Class-T Power In:
https://www.currentconnected.com/pro...iAAEgKBmfD_BwE
"If you can't send money, send tobacco."
-George Washington
12-05-2024, 05:11 PM
#25
Journeyman
Amherst
, Massachusetts
Tell me more... I'm clueless about this level of detail...
12-06-2024, 06:00 AM
#26
Nashua
, New Hampshire
It's actually pretty simple, if you pull both cables off of one battery, that battery will take the bulk of he load and they others will take less. They won't charge evenly, either. This leads to battery imbalance.
With two batteries, pulling the positive lead off one and the negative lead off the other insures that they share the load and charge evenly.
When you add more batteries, this still works to an extent, but the middle battery (or batteries) takes less of the load and charge. At that point, the best solution is to use bus bars for both the positive and negative connections.
Run equal-length cables from each positive battery terminal to the positive bus bar. You can use your main battery fuse block as a bus bar and just run the three (or more) battery cables to one side.
You also need to run equal-length cables from each battery to the negative bus bar, but they don't have to be the same length as the positive cables. If you're using a chassis ground, you can run all three negative cables to the same ground point, if that's easier.
When I did our lithium conversion, I started with one 300Ah battery. When I added a second battery, it was simpler to go the bus bar with chassis ground route, but it wasn't strictly necessary. In the pic, you can see the positives going to the main battery fuse and the negatives to a chassis ground.
12-06-2024, 06:09 AM
#27
Nashua
, New Hampshire
[QUOTE=StogieMan;2762911]Now I have triple redundancy as our 460 Ah Epoch batteries have built in class-t fuses. Now we have an MRBF fuse on each positive battery terminal, a class-t fuse 8” from the closest battery positive terminal and one each class-t fuse in each battery. Hey - I can sleep better at night!QUOTE]
All this really does is add several unnecessary connections that increase resistance in the system and create more potential points of failure. Ask an electrician and they'll tell you the fewer connections, the better.
12-06-2024, 06:16 AM
#28
Husqvarnia
, Husqvarnia
All the cabling and balancing requirements for multiple batteries is one of the reasons I prefer a single-battery solution. Another is the increased possibility of a bad battery when multiple batteries are involved. Premature failure of one battery will usually necessitate swapping all batteries out, because it’s inadvisable to mix batteries of different ages.
12-06-2024, 10:06 AM
#29
2021 16' Bambi
Forest Lake
@Byn describes it well. Battery imbalance can be a big deal with lithium batteries. There's another thread (can't find it) where the poster ruined his Battleborns with an imbalanced topology (as they call it). One battery was being constantly drained and recharged while the others never received a balancing voltage (from what I gather).
Anyways, having positive and negative bus bars is ideal, but you can just rearrange your cables and get close enough to ideal. I labeled your batteries and you can move the negative cable coming in from #2 to #3. Then move the negative cable going from #3 to #1 to between #3 to #2 (hopefully it reaches). Leave the positives as they are.
With our 4x100Ah under the bed I couldn't get the cables to be equal length which is closer to ideal, but I'm not too worried since I don't think the wire resistance is that significant. And I have cheap batteries, so it's not as big of an investment. I expect batteries will get even smaller and maybe in a few years I can put 8x100Ah in the same space.
2017 Audi Q7 3.0T
WBCCI 6343
12-06-2024, 11:50 AM
#30
2018 30' Classic
Spokane
On 7/23/24, I spoke with James at Epoch Batteries, and he told me that trimming a handle off the side of the battery would NOT affect the warranty, unless you caused some actual damage to the battery itself.
I used a hack-saw to easily cut just a bit off of one handle and that allowed the battery to easily fit into the box.
12-06-2024, 11:55 AM
#31
Husqvarnia
, Husqvarnia
That seems much more reasonable/sensible. It is too bad the answer seems to depend on who happens to answer the phone.
12-07-2024, 08:58 AM
#32
Nashua
, New Hampshire
Get it in writing! Even an email is enough.
12-14-2024, 10:49 AM
#33
2010 23' FB Flying Cloud
Canmore
, Alberta
Epoch Battery Demensions
Here is the spec sheet on the Epoch 12V 300Ah | Heated & Bluetooth | LiFePO4 Battery
My battery box on a 2024 27 is 15" x 13. It looks to me like the current battery will fit just fine.
Am I wrong?
https://cdn.shopify.com/s/files/1/02...f?v=1692809717
12-15-2024, 12:52 AM
#34
2016 27' Flying Cloud
Danville
Originally Posted by Bigboote
That's what I thought, because I looked at the same spec sheet. But if you go to this other part of their website here:
https://www.epochbatteries.com/produ...och-essentials
And then go down to
Weights and Dimensions:
Weight: 58 (LBS)
DIMENSIONS
Length: 13.75" @ Base, 15.5" @ Handles (inches)
Width: 7.75 (inches)
Height: 10.5 (inches)
Note it will show the width of 15.5" where the handles are. The problem is that handles are part of the batteries body, and therefore they would have to be trimmed 1/2 inch if you want to put it into many of our battery boxes. I called Epoch and they told me that I would void my warranty if I trimmed the battery case, another member called too and they told them it wouldn't.
The spec sheet is very misleading because it is the measurement of the base versus widest part of the batteries at the built in molded handles.
12-15-2024, 09:40 AM
#35
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Sorry the Epoch 300AH would not work for you. I just saw the LiTime 100AH Group 24 with Bluetooth are on sale $199/each. I paid $250~ each for these back in Aug. and we are very happy with making the switch from Lead Acid. Recently went 5 days without charging using lights and furnace, and still had 57% charge left.
https://www.litime.com/products/12v-...mart-bluetooth
12-18-2024, 09:13 AM
#36
Journeyman
Amherst
, Massachusetts
I'm not sure I fully understood your directions, but I gave it a go (and added a disconnect). How does this look to you?
12-18-2024, 02:42 PM
#37
2021 16' Bambi
Forest Lake
Maybe I instructed you wrong, but not there yet. The negatives should go from #3 to #2 to #1. The positives from #1 to #2 to #3. So basically the last negative should end up at the battery where the positive comes in. And the last positive should be the battery where the negative comes in. So just switch the negative from #3-#1 to #3-#2.
2017 Audi Q7 3.0T
WBCCI 6343
12-19-2024, 08:39 PM
#38
Journeyman
Amherst
, Massachusetts
Ah... that makes sense (and I see now how that's what you told me the first time).
Any concerns/modifications I should make because of the two positive leads? Should they both be at one end of the array?
THANKS!
12-19-2024, 08:46 PM
#39
1988 32' Excella
Robbinsville
, New Jersey
THANKS!
Yes they should both be at the end.
12-20-2024, 09:06 AM
#40
Journeyman
Amherst
, Massachusetts
At one end? Or can they be one at each end, as is currently the case?
