Old 12-17-2018, 01:17 PM   #1
2019 25' Flying Cloud
Lakewood , New Mexico
Strange Battery Disconnect Noise
I'm a first time AS owner of a 2019 FC 25RB and I cannot find an answer for an unusual noise when I engage the battery disconnect from store to use. I hear the relay engage, but also there's a strange noise, what sounds like a motor running a screw rod, about 2 feet above the switch. The "motor" noise lasts about two seconds. Everything works like it should, but I don't understand the noise or what's causing it. Can anyone give my an explanation?
Rex
BigTexRex is offline   Reply With Quote
Old 12-17-2018, 09:31 PM   #2
Journeyman
2016 25' International
Amherst , Massachusetts
I think you are hearing the stereo shutting itself down. I believe it tries to eject any disc that's inside when it powers off, and if there is no disc then it just makes a noise.
thiel is offline   Reply With Quote
Old 12-18-2018, 07:13 AM   #3
THANK YOU...that makes sense and mystery solved.
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 4 08-07-2020 10:13 AM
Clicking noise coming from main battery disconnect switch drguthman Electrical - Systems, Generators, Batteries & Solar 1 07-11-2018 07:16 AM
Strange noise-Solar? clemdogmom Generators & Solar Power 5 11-04-2011 08:05 AM
1993 B190 with 460,strange noise! jhaun48 Sprinter and B-van Forum 5 10-28-2008 03:10 PM
Strange noise coming from the wheels wayne.yl Brakes & Brake Controllers 21 07-16-2008 03:38 PM
