Old 02-24-2018, 12:47 AM   #1
John the Basque
2016 30' International
Chaska , Minnesota
Stock power converter blowing 30A fuses
I have a 2016 Serenity 30’ 50A service. The stock power converter is no longer charging my batteries. The unit is blowing the pair of 30A fuses. I disconnected shore power and switched to store mode. Installed new fuses, as soon as I switched from “store” to “use” the fuses blew again. Any ideas as to why? Thanks in advance.
johare22 is offline   Reply With Quote
Old 02-24-2018, 03:56 AM   #2
Sag Harbor , New York
Sounds like your converter may have gone bad IMO, but this is just a lay opinion. Hopefully an expert will check in later this morning. Further info may be in these search results for "converter bad 2016" --
https://www.google.com/search?q=conv...=airforums.com
Is your shore power setup the same as has worked alright before? By 30 amp "fuses" are you referring to a house/garage old-fashioned fuse panel [vs. a more modern circuit breaker panel]? Any chance there is a loose connection in your 120-volt wiring? How about the shore power plug and outlet, are they in good condition?
If "fuses" refers to the Airstream's 12-volt distribution panel, I thought that had circuit breakers not fuses? Maybe the confusion is all mine, but perhaps you could clarify the terminology/location of the "fuses." Thanks.
Good luck!
Peter
Old 02-24-2018, 06:54 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Either the batteries are connected in reverse polarity or the converter is bad.
I am refering to the fuses in/on the converter itself.
Old 02-24-2018, 07:03 AM   #4
John the Basque
Chaska , Minnesota
Shore power not involved, batteries not connected in Reverse. Fuses are green auto type located on far right side of converter stacked. Read my original post carefully don’t guess.
Old 02-24-2018, 07:05 AM   #5
John the Basque
Chaska , Minnesota
More interest in “root” cause possibilities
Old 02-24-2018, 09:18 AM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
A guess: You have a dead short either within the output of the converter or in the wiring to the batteries. Take a meter and check from the fuses on.
Old 02-24-2018, 10:07 AM   #7
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Are the batteries shorted out, internal battery short?
Old 02-24-2018, 10:36 AM   #8
1999 25' Safari
Sparks , Nevada
Remove and insulate the battery connection, at the battery. Either positive or negative will do. Put in new fuses and try again. If the fuse holds at the converter then measure the voltage with a meter at the converter. If you have 12v lighting in the AS then you have a bad battery. If not then it becomes a little more involved. You could then remove cables going to the battery at the converter and then measure the voltage with a meter at the converter. If good then you have an AS problem.
Vich is offline   Reply With Quote
Old 02-24-2018, 12:42 PM   #9
John the Basque
Chaska , Minnesota
Thanks Vich the batteries are brand new installed yesterday
Old 02-24-2018, 01:23 PM   #10
1999 25' Safari
Sparks , Nevada
Those two fuses being blown is suggestive of reverse battery (now or earlier) - However it may be the converter itself. Easiest way it find out is to remove cables going to battery at the converter (be sure to insulate or disconnect at the battery), then turn on shore power (converter input) and measure output voltage of converter. If output of converter is >13V then you most likely have an problem at or near the batteries.
Old 02-24-2018, 02:14 PM   #11
Gainesville , Florida
Betcha its either the newly installed batts or the connections.
Old 02-24-2018, 03:03 PM   #12
Did the problem start only after you installed the new batteries? Or did the problem exist before this, with the old batteries?
Old 02-24-2018, 03:50 PM   #13
2017 30' International
Cumming , Georgia
Just replaced mine
I have a 2017 International Serenity 30 and I noticed my converter fan was running 24 hours, never turned off. This was not normal. Called the dealer, they said sometimes it happens, don’t worry about it.
Then I called Airstream, they said it can happen. I looked at my battery level on the Sea-level meter, showed 12.0 Volts. Airstream tech said that’s a problem, it should read 13.6 - 13.8V while plugged into shore power with battery disconnect switched to “Use”. I had my batteries tested, they were good . My dealer then replaced the converter under warranty.
I learned a lot , and now better understand how to monitor my batteries and the converter. Sounds like your converter has gone bad too. It’s a quick easy replacement. I would recommend you replace yours with a new 3 stage that won’t over charge your batteries if you stay plugged to shore power for long periods.
Good luck!
Scott59 is offline   Reply With Quote
Old 02-24-2018, 04:33 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
What brand and model number is the converter?
Can you post a pic of the fuses you are referring to?
Showing where they are located.
Old 02-24-2018, 07:39 PM   #15
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
FWIW, I have had bad batteries blow the converter's output fuses. Changed batteries and fuses and everything was OK. Had a friend who installed his batteries backward and got the same result as you. Better recheck the battery connections. You probably did not harm the converter. That's what the fuses are for. While you are at it check you battery output circuit breaker or fuses. They could now be blown and gone from reverse polarity.
guskmg
Old 02-25-2018, 12:59 PM   #16
1988 25' Excella
1987 32' Excella
So, did you find the problem yet?
Old 02-26-2018, 01:27 AM   #17
John the Basque
Chaska , Minnesota
Problem existed prior to new battery install was fine a month ago. Suspect converter, no cable issues going into unit need to check wiring harness coming in from A frame but that is more involved.
Old 02-26-2018, 01:32 AM   #18
John the Basque
Chaska , Minnesota
guskmg
The polarity is not the issue here. This the old batteries just prior to removal and replacement. After 2 years hard use.
Old 02-26-2018, 01:36 AM   #19
John the Basque
Chaska , Minnesota
I’ll take that bet, problem existed prior to new batteries, worked great for the last 2+ years until this past week.
Old 02-26-2018, 01:41 AM   #20
John the Basque
Chaska , Minnesota
Fuses are a pair in upper left corner of fuse / electric panel, they are green with 30 printed on the facing edge. They are above all other fuses and circuit breakers and isolated from the operational panel.
Fuses, Fuses, Fuses PSU1981 Electrical - Systems, Generators, Batteries & Solar 9 10-13-2017 11:54 AM
Campground 30A Blowing?! JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 8 06-01-2013 08:49 PM
Blowing Fuses When Plugging Into Shore Power 1hank1 Electrical - Systems, Generators, Batteries & Solar 1 04-24-2012 08:29 PM
Blowing fuses on shore power fotochop Lights - Interior & Exterior 16 01-27-2010 08:00 AM
30A Upgrade to 30A + 20A Wayne Olson Classic Motorhomes 10 12-12-2006 03:51 PM
