03-28-2019, 06:33 PM
Vienna
, VIRGINIA
Source/advice for Battery cables/connectors
I’m replacing my nonexistent 12v battery with 2x6v Lifeline AGMs. Looking for a advice & source for cables. Batteries, converter/charger all going under the rear twin.
2001 Ford Excursion 7.3L
03-28-2019, 06:35 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Check with Randy at Best Converter.
http://www.bestconverter.com/
03-28-2019, 07:05 PM
2017 25' International
Niagara-on-the-Lake
, ON Canada
A good source for custom cables is either a marine yard or a tractor/farm equipment dealer.
Ray B.
03-28-2019, 10:24 PM
2007 22' International CCD
Corona
There is a wide variety of battery cable assemblies available on Amazon. I use Marine grade cables with 3/8 inch ring terminals in red and black as applicable. Lengths go from 12 inches to multiple feet. The terminals are sealed with adhesive lined shrink tubing to prevent corrosion.
03-29-2019, 07:54 AM
Curtis Wright
Eyren Haven
, South Jersey
The best for cables is Genuine Dealz in Georgia. Real fast turn around, quality work. I use garden hose to find the length through the routing. http://www.genuinedealz.com/custom-c...cable-assembly
Also Bay Marine Supply in California.
03-29-2019, 08:28 AM
Breckenridge
I had a good experience with http://batterycablesusa.com
03-29-2019, 09:20 AM
2004 30' Classic
Johnson City
UL-Listed products
Recommend using cable and lugs that meet or exceed UL 1426, rather than cheap welding cable. This normally means using marine-grade products, such as Ancor cable assemblies. I order custom length Ancor cables with lugs from PKYS.
73/gus
Gus - KR4K : Mary - K5MCL
2004 30ft. Classic
2017 Infiniti QX80 Limited
ProPride 3P/Prodigy P3
03-29-2019, 09:39 AM
Vienna
, VIRGINIA
For short runs (less than 3’), do these need to 2, 4 or 6 AWG cables?
03-29-2019, 09:40 AM
Vienna
, VIRGINIA
Thanks everyone for the sourcing options !
03-29-2019, 09:58 AM
Corona
Cable size depends on how many amps you need to draw through them and the length. Look for an “ampacity table” to get a feel for minimum size needed for a given run, and go the next size up or so.
I’m planning a small inverter, so my Airstream OEM cheap 10 gauge exterior battery wiring is going up to 4 gauge marine wire assemblies in this upgrade.
I also had a boiling battery issue that spewed acid all over the factory wiring, and the wire and lugs did not fare well. Time to replace and upgrade with better materials.
03-29-2019, 12:17 PM
2020 25' Globetrotter
Half-timer from
, New Hampshire
Add this source to the list of recommended cable suppliers:
https://www.acdcwireandsupply.com/Default.asp
I received my order of seventeen 4/0 cable assemblies from them yesterday and I'm very impressed with the quality and construction. Also, the order processing and delivery speed was very fast. I placed the order Friday morning and it arrived the following Thursday, from their place in Michigan to my address in California.
Bonus:
The prices were substantially less than the other suppliers mentioned above that I checked for the same spec cables.
03-29-2019, 02:02 PM
Vienna
, VIRGINIA
I’m glad I opened the box of my PD9260 converter that I purchased last year but had not installed...didn’t realize that it didn’t include cables.
