I’m pretty sure I’m not imagining this. On an outing last week with my ‘90 Excella I was hooked up to 30w shore power. I always use a 120 outlet in the front to charge my iPad and iPhone. I swear it took much longer for them to charge as it normally does at home.
Any ideas?
John
John Audette
Air Cooled Porsche Specialist -
Two roads diverged in a wood, and I took the one less traveled. ~ Robert Frost
If you have an incandescent light bulb (can you still buy one) , plug it in and compare brightness to in the house. While it is plugged in and turned on, check the voltage on the second outlet, it should be near 120 but at least 110. swap outlets and check again.
