Old 01-20-2021, 03:16 PM   #81
2017 30' International
Middletown , Ohio
Mis-wired
Originally Posted by gccoates View Post
I just finished installing a new PD4655V in my 2019 16 Caravel. Took a bit longer than expected but it worked out well. The main confusion I had was the lack of a VCC+ port. I joined the two red positives in the available port on the new board. It all works except my battery disconnect switch. Is that because the convertor has this function built in?
While I do not have the same trailer or original converter/charger you had, I did replace the Parallax converter/charger in my trailer with a Progressive Dynamics unit.
I believe you have mis-wired your new installation. In my Airstream, there is a 6AWG wire that runs from the batteries thru the disconnect switch relay to the low voltage fuse block and terminates on the center lug of the fuse block. The POS wire from the converter/charger should terminate on a separate lug on the low voltage fuse block. If you have both of them on the same lug, you in effect over ride the disconnect switch.
Check your low voltage fuse block. While I am unsure yours and mine are the same, there are three lugs ... the one on the left is not used, the center lug connects to the converter/charger. The right lug connects to the battery via the battery disconnect switch.
As a note the negative from the batteries and the converter charger should land on a terminal block reserved for negative wires. This is not the same as the neutral bar in the power section.
Hope this helps.
RJKSr is offline   Reply With Quote
Old 02-18-2021, 09:44 PM   #82
bainbridge island , Washington
Thank you for the reply. Im wondering if I could send you a few photos of my old set-up and new to compare? If so, I can email or text them to you. Let me know if youd be willing to take a look
Glenn
gccoates is offline   Reply With Quote
Subfloor *should we let it done or should we do it on our own severin Repairing/Replacing Floor &/or Frame 2 04-25-2019 07:54 PM
Should I upgrade converter? CAV Batteries, Univolts, Converters & Inverters 21 10-24-2017 10:16 PM
Are we crazy?? Should we or should we not sell... Bhkh226 Trailer Values 26 02-03-2017 06:40 AM
Should I buy or should I run away ddruker Ribs, Skins & Rivets 16 04-15-2012 10:35 AM
Should we or should we not Angel73 Floor Finishes 12 03-18-2007 08:48 PM
