Old 09-30-2020, 09:27 PM   #1
2020 30' Flying Cloud
Fayetteville , Georgia
Running wire through the belly pan?
Hey guys,
I am at a loss. To connect my inverter to the SPS and electrical panel, I need to run two 6/3 wires plus a couple of data cables from the front of my FC 30FB Bunk to the electrical panel. I would like to keep the wires hidden.
There's already two DC wires in a fabric sheath that runs into the flooring at the main electrical panel and out of the front side of the belly and back up through the floor to the DC panel in the front storage compartment. so I know it can be done.
Can I partially lower the belly pan, install the wires and reinstall the rivets once I'm done? Sounds time consuming.
How much trouble would it be to run a 2 or 3 inch PVC pipe or conduit through the belly pan to run the wires?
Is there a better way?
Thanks in advance.
Tony
T Mac is offline   Reply With Quote
Old 10-01-2020, 12:08 AM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Putting in the pvc conduit will be more work, but it does help for future repairs/additions. I took the time to add it throughout the belly pan when I did the frame up on my 58.
Name:	Conduit curb side (2).jpg
ID:	379795 Click image for larger version
Name:	conduit street side rear.jpg
Frame's upside down on my rotisserie.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 10-01-2020, 05:44 AM   #3
Thanks for the reply.
Nice job! I wish I could turn my trailer upside down to work on it. On second thought, that would mean I have a lot of additional work to do before I can install the upgraded inverter.
It looks like you had to drill through the cross beams to install the conduit fore and aft. I thought there might be some holes I could snake through. I guess Iíll have to drop some of the belly pan to take a look.
Thanks for sharing,
Tony
Old 10-01-2020, 06:01 AM   #4
1988 Argosy 32
Lomita , California
can you run the pipe on the outside of pan ??
Wolfe is offline   Reply With Quote
Old 10-01-2020, 07:57 AM   #5
DaveP's Avatar
2004 28' Classic
Monument , Colorado
I ran my wires under the cabinets. That might work on you depending on the layout.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 10-01-2020, 11:34 AM   #6
DonRich7878's Avatar
2013 30' Classic
Key West , Florida
Originally Posted by T Mac View Post
Hey guys,
Thanks in advance.
Tony
I installed a DC power cable from the battery box at the front to a macerator plug in at the rear bumper, and a bumper backup camera cable using flexible liquid tight conduit riveted to the outside of belly pan.
https://www.lowes.com/pd/Southwire-C...onduit/3129269
DonRich7878 is offline   Reply With Quote
Old 10-01-2020, 05:03 PM   #7
I called Am Solar (where I bought most of the components) and there recommendation is either:
run the wire out from under the queen bed along the wall through the bulkhead that separates the bedroom from the lounge and then under the couch, sink, stove then under the cross over tunnel to the area below the fridge. This could have exposed wire for about 3-4 feet which I would have to manufacture a rather large wire mold.
Run the wire along side the two factory installed 6 gauge DC wires starting under the bed, through the floor, enter the front side of the belly pan area and then back up through the floor under the fridge. No wires exposed. That's the direction I'm looking at now.
Thanks for all the ideas. Keep em coming. I have started yet. I may change my mind again.
Tony
Old 10-01-2020, 06:20 PM   #8
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I had a similar challenge with my 27FB. No way to run wires internally with a queen bed without some ugly wall trim or drilling out many rivets to somehow put the wires into the wall.
I chose instead to run a new conduit below the belly pan following the propane gas line from the front of the camper to a point near the electrical panel, about 10 feet away. I used flexible Liquidtight conduit which you can find at any big box home store. There's also 90 degree connectors that attach the ends to the belly pan or plywood floor. Completely waterproof. I think I used heavy duty zip ties to hang it off various connection points. Worked great for 7 years now.
Example:. https://www.homedepot.com/p/Southwir...4321/202316470
kscherzi is offline   Reply With Quote
Old 10-07-2020, 09:28 AM   #9
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
How large is your inverter? I donít understand why you would need 6/3 cable.
Dan
Old 10-07-2020, 03:36 PM   #10
It's the Victron 12/3000/50. 3000 watts. I bought the stuff from AM Solar and that's the size they recommended.
I ended up running wire in the belly pan.
Old 03-29-2021, 11:14 PM   #11
LL2
LL2's Avatar
2012 27' FB International
Spokane , Washington
Did anyone happen to see the conduit under the curb side nightstand on a 27FB? Anyone know where it goes?
LL2 is offline   Reply With Quote
Old 03-30-2021, 09:25 AM   #12
LL2
LL2's Avatar
Did you have any pics of how you ran that? How far does the conduit out of the bedroom giant where does it terminate?
Old 04-04-2021, 03:22 PM   #13
2010 27' FB International
Goliad , Texas
You can undo the belly wrap, run cable, then rerivet belly wrap and trim. Pain to do, but at least it is inside.
robapperson is offline   Reply With Quote
Old 04-05-2021, 11:49 AM   #14
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Seal-Tite DC run.
When I ran (2) #4 DC home runs from my solar box on the roof to the Solar charger in the front compartment I ran behind the pantry down to the power distribution real then out under the water heater in seal-tite up to the front. Been working fine for 8 years for me. Vinnie (Vinnies Airstream repair) found a nicer path by removing the black banana wrap and running the seal-tite through the holes in the frame outriggers (they have supporting flat flanges at each hole) to keep the pipe inside the banana wrap. Too late for me!
Name:	Seal tite - 1.jpg
ID:	392486   Click image for larger version
Name:	Seal tite - 2.jpg
SuperTrouper is offline   Reply With Quote
Old 04-05-2021, 11:38 PM   #15
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Lew Farber did my install. Ran 6/3 wire along the wall in the interior of the coach. Lew fabricated aluminum covers for the 4í exposure in the bedroom. Looks like it came from the factory this way - blends right in.
wulfraat is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 08:41 PM
Accessing Chassis through Belly Pan KelseyWander Repairing/Replacing Floor &/or Frame 1 02-16-2018 11:22 AM
Replacing my belly pan and drilled through my black water tank bwilson1 Airstream Trailer Forums 17 08-23-2014 10:14 AM
waste water tanks falling through belly pan Massey Waste Systems, Tanks & Totes 7 10-22-2013 12:59 PM
Running 12 volt wire through refrigerator vent wolverine Electrical - Systems, Generators, Batteries & Solar 5 01-19-2013 11:35 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
