Old 06-02-2018, 01:58 PM   #1
1970 27' Overlander
Fayette , Alabama
Replacing a 1970 newmark converter to what?
I have just purchased a 1969 27' overlander. I have been looking at the old style Newmark, power converter, battery charger. Model DCV 50 f. I guess that would be something I need to upgrade. It has a loud HUMMMMMM to it. Ideas on what I would need to accomplish this. And any other upgrades that would be associated with this. I am familiar with house wiring and some vehicle wiring.
NoStew is offline   Reply With Quote
Old 06-03-2018, 04:21 AM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Progressive Dynamics converter chargers are popular replacements. If your converter contains your fuses, you'll also need a fuse box.
Are you planning any other upgrades in the future, or do you just want to replace the converter?
Progressive also makes some nice AC/DC power stations for those rewiring their trailers. If you were adding an inverter, some inverter models have converter/charger capabilities which eliminates the need for a separate device. If you were considering using lithium batteries in the future, you'd need a converter that could handle that charge profile.
TheGreatleys is offline   Reply With Quote
Old 06-03-2018, 05:23 PM   #3
1970 27' Overlander
Fayette , Alabama
My plan is to get the electrical components up to date. We do not plan on using any gas for power, it will all be shore power or generator. So when i plug into 120 volts, the hot water heater, refrigerator, ac unit, and the lights work. It does not look like anything has been updated in a long time, and I'm sure there are alot better components on the market. I do not plan on lithium anytime soon, although that may be a mistake.
2017 converter vs. 2018 converter. Mollysdad Batteries, Univolts, Converters & Inverters 14 06-01-2018 06:11 PM
Converter fuse blowing (new converter) wannaroam Batteries, Univolts, Converters & Inverters 28 07-06-2015 02:39 PM
Univolt 45 amp converter to a 30 amp converter scooterbug76 Batteries, Univolts, Converters & Inverters 15 02-24-2013 02:59 PM
Help with Newmark! Is my converter bad? RogerLG Batteries, Univolts, Converters & Inverters 7 10-07-2012 08:11 PM
Newmark wiring SANDDEVIL Batteries, Univolts, Converters & Inverters 4 08-03-2007 10:07 AM
