Old 09-27-2020, 05:49 PM   #1
2020 25' Globetrotter
Up North , Michigan
Removing WFCO inverter
I have installed a new victron 100/3000 inverter, in the process of removing the stock WFCO.
Looking for input on what to do with the original AC in and out leads going into and out of the WFCO. Should I leave both lines and terminate the romex that is the ac out and leave the 3-prong ac plug that supplies ac to the wfco? Or track it down and disconnect from whatever input on the ac panel that it is wired into? The wfco is wired in with romex, while I ran new 10/3 cable for the Victron.
Thank you in advance!
Mark
Greatlaker is offline   Reply With Quote
Old 10-06-2020, 09:58 AM   #2
2016 30' International
redondo beach , California
My old WFCO had a pass through.
I think that means when there is shore power the shore power could pass through to the dedicated inverter receptacles.
If you already installed a new inverter and it works I would remove the old WFCO and terminate both lines.
I would label the terminated lines for the next guy.
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 10-07-2020, 08:53 PM   #3
2020 30' Flying Cloud
Fayetteville , Georgia
I have a Flying Cloud 30FB Bunk. My inverter was in the front storage area. IF I understand the wiring diagram in the owner's manual, there's a direct line from the AC panel (circuit 7) to the inverter. The A/C plug coming from the inverter is plugged into an outlet. The wiring from the outlet goes aft and powers the outlets by the TV and dinette (essentially the outlets powered by the inverter).
I was advised by AM Solar to connect the wiring that went to the inverter to the outlet so it can get power.
I haven't tested it yet because I'm still working on my install.
Hope this helps,
Tony
T Mac is offline   Reply With Quote
Old 10-07-2020, 09:00 PM   #4
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
In my trailer 120v out was re-purposed for 12v out and the face plates that were dedicated to inverter power were changed out for USB ports.....
wulfraat is offline   Reply With Quote
Old 10-08-2020, 07:14 AM   #5
Up North , Michigan
Great ideas and direction, thank you all!
WFCO WF5110H Inverter RivetingTrvl Airstream Classifieds 0 04-19-2016 03:03 PM
WFCO WF5110H Inverter - PRICE DROP RivetingTrvl Airstream Classifieds 0 06-21-2015 12:48 PM
WFCO WF5110H Inverter ghaynes755 Airstream Classifieds 0 05-25-2015 07:01 PM
Modification to reduce fan noise for the WFCO 1000 W Inverter alano 2011 - 2015 Classic (all lengths) 8 05-08-2015 01:26 PM
WFCO WF5110H Inverter ghaynes755 Airstream Classifieds 0 07-24-2014 08:28 PM
