Old 10-01-2017, 07:29 PM   #1
1995 30' Excella
Harper Woods , Michigan
redoing the '94 Univolt 12VDC system
Hello, right now I'm working on weathertightening a '94 Excella 28', but at some point I'm going to examine and update/modify the electrical system. Currently the 12VDC system is operating with the original 1994 converter, without batteries in place and the battery cables insulated.
What are the options for updating to a reliable 12VDC power configuration? - converters, generators, solar?
Bob Blarney is offline   Reply With Quote
Old 10-04-2017, 09:00 PM   #2
New Borockton , Alabama
Images: 21
If your 94 Univolt/Converter is original, you likely have a Magnetek and they are not designed to work without a battery for filtering and regulating the DC output.
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp, Smartplug, AGM Batts
888-828-1893
Bestconverter.com
Old 10-05-2017, 03:02 PM   #3
1995 30' Excella
Thanks.
Well, I tested the voltage with a DVM. Depending on the load (i.e. the number of 1156 bulbs turned on), the voltage reads between 13 and 14 volts. I don't have an oscilloscope handy to look at the waveform, but I could go fetch one if needed.
Old 10-08-2017, 10:53 PM   #4
Images: 21
It's likely going to vary since they don't have internal filtering. New units do. You have to keep a healthy battery in the system to filter/regulate the voltage.
888-828-1893
Bestconverter.com
Old 10-10-2017, 06:10 AM   #5
1995 30' Excella
Well, then I'll keep it shut off unit I can replace the batteries. I'm still considering whether to go solar first, and then change out the converter later if the solar system can't keep up to the demand.
12v
Redoing interior walls tslanier Upholstery, Blinds, Walls & Interior Finishes 7 11-23-2007 08:04 PM
Redoing countertops tslanier Cabinets, Counter Tops & Furnishings 1 10-20-2007 05:51 AM
Redoing my 25 year old mistakes - 1963 GT ChicknKathy 1960 - 1964 Globetrotter 5 04-01-2007 05:41 PM
Redoing a 31' Sovereign LI Pets 1974 - 1979 Sovereign 13 12-28-2006 08:43 AM
We Are redoing her over ladyvain730 Our Community 2 05-07-2003 08:55 PM
