Old 08-16-2011, 10:09 AM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Rebuild battery boxes or not ?
Was wondering if anyone has rebuilt battery box's in a 1967 landyaht sovereign there located each side of lp tanks in front of trailer. I am wondering if I just want to get some sealed batteries and seal up battery area's. I guess the box's if you can find them are like 300 bucks each.
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 08-16-2011, 11:37 AM   #2
The battery in the 66, 67 and 68 Airstreams, were all in the one stop center, at the rear end of the trailer.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-16-2011, 02:09 PM   #3
1975 29' Ambassador
Reno , Nevada
re: "wondering if I just want to get some sealed batteries and seal up battery area's."
sealed batteries (even AGM's) still should have a properly vented battery box (by code).
bryanl is offline   Reply With Quote
Old 08-17-2011, 11:47 AM   #4
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
Just Resto it!
Don't replace your battery stand, just pull it out, clean it up and put some POR-15 on it, then paint and reinstall. It will never again be an issue for you. I did mine, came out nice. Keep it as original as you can. Also its a good idea to install a simple shut off switch between the cables when winterizing. Saves your battery from discharging.
Randy
Randy Gates is offline   Reply With Quote
Old 08-17-2011, 11:51 AM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I don't think those boxes are original. Airstream put the battery in the back as Andy mentioned, and also never had more than one battery in those years
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
RickDavis is offline   Reply With Quote
Old 08-23-2011, 09:16 AM   #6
1977 31' Sovereign
Images: 33
This a 76 Sovereign .
Looks original the original univolt was up front behind couch covered with same covered aluminum . I might just seal around entrance and reinforce the back and bottom I can see light through weak plastic I have some plastic weld I got from Lowes. even with out towing water is comming in that way .
K/N Cool intake air
Duel power exhaust
Old 08-23-2011, 10:55 AM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Which year are you asking about? Your original post said 67, but I notice under your name you list a 77 sovereign.. Somewhere in that time frame they did have 2 battery doors in the front
13 Ram 2500 TD
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 02:33 PM
Battery Issues imuir Batteries, Univolts, Converters & Inverters 29 08-08-2011 07:27 PM
Sealing battery boxes and doors Eugiepayset Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 06-21-2011 06:39 PM
